> Oil Pressure sender hose blew out, need help
rgolia
post Oct 23 2017, 09:51 AM
GeoJoe
So last night the hose from the engine to the oil pressure sender blew out and sent oil everywhere. fortunately I was about 1 mile from home. Lot of oil everywhere, hopefully I did not fry the engine. of course to figure that out I need to get a new sender in place. I would like to have a sender that works the green idiot light and can also work a gauge and of course I would rather not have a hose after this incident. Any suggestions on the sender type and where to get it and what to expect when i try to restart the car...after adding oil of course! (IMG:style_emoticons/default/sad.gif)
GregAmy
post Oct 31 2017, 10:16 AM
- Put suspect numbers-matching engine in the basement.
- Install good used engine into car (re-installing with not-numbers-matching Webers...natch...)
- Enjoy car.
rgolia   Oil Pressure sender hose blew out   Oct 23 2017, 09:51 AM
Keith914   Buy a 928 SS braided brake line (Bruce Stone's...   Oct 23 2017, 10:06 AM
bdstone914   Buy a 928 SS braided brake line (Bruce Stone...   Oct 24 2017, 08:20 AM
GregAmy   To clarify...if it was the hose that failed, why d...   Oct 23 2017, 10:40 AM
cuddyk   Check this out. Great kit. http://www.42draftdes...   Oct 23 2017, 10:41 AM
NeunEinVier   Check this out. Great kit. http://www.42draftde...   Oct 31 2017, 11:04 AM
era vulgaris   So last night the hose from the engine to the oil...   Oct 24 2017, 08:14 AM
Vacca Rabite   About the dual senders. I don't like them. Th...   Oct 24 2017, 12:15 PM
Mark Henry   About the dual senders. I don't like them. T...   Oct 24 2017, 02:56 PM
GregAmy   About the dual senders. I don't like them. ...   Oct 24 2017, 02:59 PM
malcolm2   About the dual senders. I don't like them. T...   Nov 13 2017, 01:14 PM
rgolia   Thanks all. I spoke with Chris at Tangerine and h...   Oct 24 2017, 02:33 PM
DM_2000   Thanks all. I spoke with Chris at Tangerine and ...   Oct 24 2017, 04:43 PM
cuddyk   The kit I linked above has 3 available ports so yo...   Oct 24 2017, 04:15 PM
rgolia   Took the strainer out....no metal frags to speak o...   Oct 26 2017, 10:03 AM
'73-914kid   I would cut open your oil filter that was on the c...   Oct 26 2017, 11:32 AM
DM_2000   Motor is probably OK unless it was in poor shape p...   Oct 26 2017, 05:22 PM
Porschef   Ralph, hope all is ok, were you using a grease gun...   Oct 26 2017, 06:45 PM
rgolia   Not sure of the origin of the hose, most likely ca...   Oct 27 2017, 09:57 AM
rgolia   Got oil back in it and fired it up. After a short...   Oct 31 2017, 09:46 AM
DM_2000   Got oil back in it and fired it up. After a shor...   Oct 31 2017, 05:00 PM
GregAmy   - Put suspect numbers-matching engine in the basem...   Oct 31 2017, 10:16 AM
McMark   - Put suspect numbers-matching engine in the base...   Oct 31 2017, 10:23 AM
Dave_Darling   Adjust the valves before you do your road test. I...   Oct 31 2017, 11:03 AM
rgolia   Fired it up this weekend and let it run for 15-20 ...   Nov 6 2017, 03:03 PM
rgolia   Well gave it a good warm up and then hit the road....   Nov 13 2017, 10:59 AM
McMark   A quick refresh isn't outside your skill set. ...   Nov 13 2017, 12:53 PM
pete000   Here is the kit I got from a Miata MX5 performance...   Nov 13 2017, 01:05 PM
Dave_Darling   Here is the kit I got from a Miata MX5 performanc...   Nov 13 2017, 02:45 PM
pete000   Here is the kit I got from a Miata MX5 performan...   Nov 13 2017, 04:21 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:05 PM
