Need Help On 6 Manual Throttle Please, Pics would be really great! |
Lucky9146 |
Oct 31 2017, 09:19 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,621 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem.
Did some poking around here on the site (IMG:style_emoticons/default/type.gif) where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal. (IMG:style_emoticons/default/idea.gif) Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version? Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out. (IMG:style_emoticons/default/confused24.gif) “Shark Fin” is on the far left. Thanks! (IMG:style_emoticons/default/white914.jpg) |
Larmo63 |
Nov 1 2017, 07:48 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
There is really not that much pressure on pushing a stock gas pedal.
At least there shouldn't be. |
SixerJ |
Nov 2 2017, 01:40 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
There is really not that much pressure on pushing a stock gas pedal. At least there shouldn't be. I agree, not much leverage can be applied by the hand crank and especially so if it only has two spot welds I guess if you were really worried you could tack a small triangular fillet on the back. In the photo the dimple kind of looks like it is coming at you but it's not. It's going towards the wood. Dimple is shallow maybe 5-6 mm max I will take a shot of the back and side tonight so they are in one thread |
Lo-Fi Version | Time is now: 10th June 2024 - 12:53 AM |
