QUOTE(Lucky9146 @ Nov 1 2017, 04:19 PM)
Received my Manual throttle assembly from 914 Rubber and it looks great! But no specific instruction regarding the “Shark Fin” and I have not seen a real one up close. I understand where and how the lever and rod go that's no problem.
Did some poking around here on the site
where I thought I might see pictures but I did not see the small “shark fin” and how and where exactly it goes on the gas pedal.
Does anybody have a good picture of the "Shark Fin" installed either real original 914-6 or 914 Rubber version?
Of course I had just got all the pedal cables hooked up and adjusted when I received the assembly not understanding how the hand throttle actually worked. I’m thinking the whole pedal assembly has to come out.
“Shark Fin” is on the far left. Thanks!
Click to view attachmentJim,good description of the shape
,I mounted this plate with one bolt and moved it once till contact with the rod ,the bolt out and plug welded the hole .
Every "6" on carbs should have one of these ,very handy for quick start up,I do 2-3 pumps on the pedal with the lever on full travel,mine starts straight up.
