| malcolm2 |
Oct 31 2017, 05:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I can think of a couple ways to fix this. Can i hear more ideas?
You can see that there are 4 weld impressions. 3 have pulled a hole in the firewall. ![]() |
| malcolm2 |
Nov 2 2017, 05:57 PM
looks like cary's combo idea might be the way to go. I was planning on leaving the bolt, but this area of the firewall is doubled. So i can't cinch the bolt down tight like I wanted to do since it is double walled. Everything will collapse. everything below the visible tack welds is single wall.
Damn. When my kids sell the car, I will tell them to blame it on the PO. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) ![]() |
malcolm2 Engine lid hinge repair Oct 31 2017, 05:12 PM
mzalanka Tape & mask window. Wire brush to metal. Tack ... Oct 31 2017, 06:08 PM
cary It will need to be patched. Most of the time the s... Nov 1 2017, 05:40 AM
malcolm2
It will need to be patched. Most of the time the ... Nov 1 2017, 07:28 AM
cary I don't have a car to look at right now. Will ... Nov 1 2017, 08:17 AM
malcolm2
I don't have a car to look at right now. Will... Nov 1 2017, 11:44 AM
mzalanka I wouldn't second guess Cary as he obviously k... Nov 1 2017, 12:33 PM
cary How about doing a combo of your two ideas. Lets us... Nov 1 2017, 09:54 PM
windforfun You might want to pull out the pad behind your sea... Nov 2 2017, 07:16 PM
malcolm2
You might want to pull out the pad behind your se... Nov 2 2017, 07:20 PM
windforfun I'm referring to the interior pad & not th... Nov 2 2017, 07:23 PM
malcolm2
I'm referring to the interior pad & not t... Nov 2 2017, 07:27 PM
windforfun Interesting. My "73 has no adhesive. In fac... Nov 2 2017, 07:33 PM
malcolm2
Interesting. My "73 has no adhesive. In fa... Nov 2 2017, 07:42 PM
windforfun BTW, the spot or tack welds just popped on one of ... Nov 2 2017, 07:45 PM
windforfun Here's the new pad. Nov 2 2017, 07:50 PM
Garold Shaffer
Here's the new pad.
I believe the pad he is... Nov 2 2017, 08:26 PM
malcolm2 Well I finally got around to finishing this projec... Nov 11 2017, 04:58 PM
cary That dog will hunt ...............
Mask it off and... Nov 11 2017, 08:05 PM
96740 I just ran into this problem too. Looks like it... May 24 2020, 01:38 PM
BeatNavy Drill out those spot welds with a spot weld bit. ... May 24 2020, 01:47 PM
96740
Drill out those spot welds with a spot weld bit. ... May 27 2020, 05:57 AM
Rikyrat Hey, I had the same problem with my hinge cracked ... May 27 2020, 11:47 AM
dangrouche here's my technique using a piece of "L... May 28 2020, 09:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:29 AM |
