malcolm2
Oct 31 2017, 05:12 PM
I can think of a couple ways to fix this. Can i hear more ideas?
You can see that there are 4 weld impressions. 3 have pulled a hole in the firewall.
Click to view attachment Click to view attachment Click to view attachment
mzalanka
Oct 31 2017, 06:08 PM
Tape & mask window. Wire brush to metal. Tack weld left side, tack weld right side. Careful with heat due to window. Fit lid. Good? Hit with 2K epoxy rattle can. Unmask window. Refit lid. Done.
cary
Nov 1 2017, 05:40 AM
It will need to be patched. Most of the time the spot welds just pop.
Now it's a time vs. money thing.
Is the engine in the car ?
malcolm2
Nov 1 2017, 07:28 AM
QUOTE(cary @ Nov 1 2017, 06:40 AM)
Oh yeah, I drive the car 4 to 5 days a week.
Won't be much money, I'll do the work, but it will be a PITA and some driving downtime.
One method I was thinking about was to remove the seats and back pad. Make a weld repair to the inside.
Then maybe drill a hole thru the vertical section of the bracket and the firewall and add small, sturdy plate inside (10 ga or thicker) and bolt it all together. I suppose I could also tack each side in the engine bay, as suggested above.
While I had the seats and back pad out, I figured I would do the bolt and plate on the hinge on the other side too.
cary
Nov 1 2017, 08:17 AM
I don't have a car to look at right now. Will there be enough room for the lid to open with a bolt in the hinge?
malcolm2
Nov 1 2017, 11:44 AM
QUOTE(cary @ Nov 1 2017, 09:17 AM)
I should have checked, prior to removing the lid. But there is a slight "gusset" on each side of the vertical part of the hinge. I will have to re-fit the lid to double check.
mzalanka
Nov 1 2017, 12:33 PM
I wouldn't second guess Cary as he obviously knows his stuff. The proper long term repair would be to cut, patch, reweld, and address any additional rust on the firewall.
The tack method, though, would be a quick fix for a driver and would be easily reversible if/when you decide on a more permanent repair. You'll need to remove the rear window for anything more significant than a tack weld as the heat could crack it and/or cause the butyl to melt/catch fire (although it kind of looks like your window might be urethaned in?). RD has the hinge bracket available cheap and you could do a thorough repair when the time is right.
http://www.restoration-design.com/store/product/PP343The spot welds on my driver side hinge gave way and I can speak to the effectiveness of two little tacks in working long-term.
cary
Nov 1 2017, 09:54 PM
How about doing a combo of your two ideas. Lets use the bolt to pull the skin and the hinge back to the firewall, then weld the sides. 3 to 4 tacks on each side. Let the metal cool to the touch between each weld. Then one tack on the top.
Then get a can of EverCote brush-on seam sealer, remove the bolt and nut and seal it up.
Then at a later date do the proper cut out and new hinge bracket.
malcolm2
Nov 2 2017, 05:57 PM
windforfun
Nov 2 2017, 07:16 PM
You might want to pull out the pad behind your seats too. BTDT.
malcolm2
Nov 2 2017, 07:20 PM
QUOTE(windforfun @ Nov 2 2017, 08:16 PM)
that yellow goo in the picture is what factory sprayed on in 1975 and used to hold that pad in. I pulled it all out in 2011. Just out of view of the above picture is B-Quiet stuck to the fire wall. You can just see a bit of it in the btm left corner of the picture.
The car used to be silver. My guess is that the PO pulled the back window and layed the crappy pad down and painted the car red.
windforfun
Nov 2 2017, 07:23 PM
I'm referring to the interior pad & not the one in the engine well.
malcolm2
Nov 2 2017, 07:27 PM
QUOTE(windforfun @ Nov 2 2017, 08:23 PM)
Me too.
neither pad is installed. There is very little room in the engine bay. So that crappy pad was pulled too. The only pad in my car is B-quiet. On the interior firewall behind the seats and on the floor.... the metal floor that I welded in. Any remaining floor that had goo on it, had the goo removed.
If you look under the 1st few pix you can see that no pad is under the hinge. The pic above is inside. the funky loops are what holds the vinyl back pad to the firewall.
windforfun
Nov 2 2017, 07:33 PM
Interesting. My "73 has no adhesive. In fact, I was able to buy a brand new interior pad from Porsche.
malcolm2
Nov 2 2017, 07:42 PM
QUOTE(windforfun @ Nov 2 2017, 08:33 PM)
Well I assumed it was factory goo. Maybe the PO's painter sprayed it on there to put the pad back. I am not sure what the pads did. I can't imagine that they helped the engine and wind noise very much. I figured I would be just as good without any of them.
windforfun
Nov 2 2017, 07:45 PM
BTW, the spot or tack welds just popped on one of the brackets without damaging the sheet metal. I had a shop bead weld both brackets around their edges. I guess I was lucky.
windforfun
Nov 2 2017, 07:50 PM
GaroldShaffer
Nov 2 2017, 08:26 PM
QUOTE(windforfun @ Nov 2 2017, 08:50 PM)
I believe the pad he is talking about is the very heavy black sound pad used on the inside that goes between the backpad & firewall. That is glued in place.
malcolm2
Nov 11 2017, 04:58 PM
Well I finally got around to finishing this project. As recommended I tacked a few places then re=fit the lid. Here is the pre-fit tack job.
Click to view attachmentThat ended up taking some time. My bolts were stripped. Once I got that straight everything fit and I tacked and tacked and tacked.....
Good enough for driving to Walmart....
cary
Nov 11 2017, 08:05 PM
That dog will hunt ...............
Mask it off and spray with Rustoleum of your choice.
96740
May 24 2020, 01:38 PM
I just ran into this problem too. Looks like it's been repaired before. How do you take the old ones off to put new ones on?
BeatNavy
May 24 2020, 01:47 PM
Drill out those spot welds with a spot weld bit. Use a chisel or old screw driver and a hammer to break what's left of the welds and get it off the firewall, but try to be careful not to tear the firewall itself. Grind off what's left.
96740
May 27 2020, 05:57 AM
QUOTE(BeatNavy @ May 24 2020, 12:47 PM)
Thank you.
Rikyrat
May 27 2020, 11:47 AM
Hey, I had the same problem with my hinge cracked across the middle which prevented the deck lid from opening smoothly, so I used a little back yard ingenuity.
What is did was go to Homer Depot, and found an L-bracket, that would fit over the nut head in the middle, cut it to length, and welded it in, would have included a photo, but my welding skills, are not the best, then painted it.
Looks as though it will hold, there is no longer any sag in it, and it seems to be fairly sturdy. I will know when I get it all back to together. As, I am working on my megasquirt setup.
Just my 2cents
dangrouche
May 28 2020, 09:38 AM
here's my technique using a piece of "L" bracket. Cut a corner off of it (or use any metal bit) as a gusset and weld it onto both sides of the hinge bracket. the long screw was used as the ground for the welding and to put tension on the bracket to close the gap of the cracks. I did not want to have to try to weld a new bracket onto thin metal or lose the placement of the OEM bracket.
Click to view attachment This was my second repair of the existing hinge bracket from 6 months earlier. for the first repair, I welded at the cracked joints, but the hinge flexed and cracked the welds. The current repair is solid and does not flex anymore.
