| malcolm2 |
Oct 31 2017, 05:12 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
I can think of a couple ways to fix this. Can i hear more ideas?
You can see that there are 4 weld impressions. 3 have pulled a hole in the firewall. ![]() |
| windforfun |
Nov 2 2017, 07:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
You might want to pull out the pad behind your seats too. BTDT.
| malcolm2 |
Nov 2 2017, 07:20 PM
You might want to pull out the pad behind your seats too. BTDT. that yellow goo in the picture is what factory sprayed on in 1975 and used to hold that pad in. I pulled it all out in 2011. Just out of view of the above picture is B-Quiet stuck to the fire wall. You can just see a bit of it in the btm left corner of the picture. The car used to be silver. My guess is that the PO pulled the back window and layed the crappy pad down and painted the car red. |
malcolm2 Engine lid hinge repair Oct 31 2017, 05:12 PM
mzalanka Tape & mask window. Wire brush to metal. Tack ... Oct 31 2017, 06:08 PM
cary It will need to be patched. Most of the time the s... Nov 1 2017, 05:40 AM
malcolm2
It will need to be patched. Most of the time the ... Nov 1 2017, 07:28 AM
cary I don't have a car to look at right now. Will ... Nov 1 2017, 08:17 AM
malcolm2
I don't have a car to look at right now. Will... Nov 1 2017, 11:44 AM
mzalanka I wouldn't second guess Cary as he obviously k... Nov 1 2017, 12:33 PM
cary How about doing a combo of your two ideas. Lets us... Nov 1 2017, 09:54 PM
malcolm2 looks like cary's combo idea might be the way ... Nov 2 2017, 05:57 PM
windforfun I'm referring to the interior pad & not th... Nov 2 2017, 07:23 PM
malcolm2
I'm referring to the interior pad & not t... Nov 2 2017, 07:27 PM
windforfun Interesting. My "73 has no adhesive. In fac... Nov 2 2017, 07:33 PM
malcolm2
Interesting. My "73 has no adhesive. In fa... Nov 2 2017, 07:42 PM
windforfun BTW, the spot or tack welds just popped on one of ... Nov 2 2017, 07:45 PM
windforfun Here's the new pad. Nov 2 2017, 07:50 PM
Garold Shaffer
Here's the new pad.
I believe the pad he is... Nov 2 2017, 08:26 PM
malcolm2 Well I finally got around to finishing this projec... Nov 11 2017, 04:58 PM
cary That dog will hunt ...............
Mask it off and... Nov 11 2017, 08:05 PM
96740 I just ran into this problem too. Looks like it... May 24 2020, 01:38 PM
BeatNavy Drill out those spot welds with a spot weld bit. ... May 24 2020, 01:47 PM
96740
Drill out those spot welds with a spot weld bit. ... May 27 2020, 05:57 AM
Rikyrat Hey, I had the same problem with my hinge cracked ... May 27 2020, 11:47 AM
dangrouche here's my technique using a piece of "L... May 28 2020, 09:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:24 PM |
