> My '70 V-8 Assembly Thread, a few updates and pic's
76-914
post Oct 14 2017, 02:44 PM
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb?
The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif)
Attached ImageAttached Image
Andyrew
post Nov 2 2017, 08:40 PM
Spooling.... Please wait
Looks good!!!
76-914   My '70 V-8 Assembly Thread   Oct 14 2017, 02:44 PM
Chris914n6   108. 50 is for the 3 bolts on the "adjustment...   Oct 14 2017, 02:53 PM
76-914   108. 50 is for the 3 bolts on the "adjustmen...   Oct 14 2017, 03:15 PM
76-914   2nd question. The new E brake cable head came with...   Oct 14 2017, 03:13 PM
zig-n-zag   I say 108 ftlbs for the nut, and the three bolts w...   Oct 14 2017, 04:10 PM
76-914   Must be 108 if both you guys agree. I couldn't...   Oct 14 2017, 05:30 PM
burton73   That spot will be covered by a Ducktail spoiler so...   Oct 14 2017, 09:03 PM
76-914   That spot will be covered by a Ducktail spoiler s...   Oct 15 2017, 09:42 AM
barefoot   . While I was at it I did the same on the left sid...   Oct 19 2017, 05:43 AM
76-914   I spent this morning doing a little house cleaning...   Oct 15 2017, 02:40 PM
KELTY360   Also took a good pic of the block casting # ...   Nov 3 2017, 07:48 PM
Andyrew   I found this on the head casting, looks like maybe...   Oct 15 2017, 06:52 PM
bulitt   Andrew thats the info I have Heads- 3998993 rebuil...   Oct 15 2017, 07:46 PM
rhodyguy   Be pointed forward when you go for the first big t...   Oct 16 2017, 07:14 AM
76-914   Be pointed forward when you go for the first big ...   Oct 16 2017, 06:47 PM
ValcoOscar   [quote name='rhodyguy' post='2538119' date='Oct 1...   Oct 16 2017, 07:53 PM
Larmo63   "Mr. Ugly" was staring back at you? ...   Oct 16 2017, 08:02 PM
76-914   I tried to install these today but their appx 1...   Oct 18 2017, 08:17 PM
Chris914n6   I tried to install these today but their appx 1...   Oct 18 2017, 11:29 PM
Mike Bellis   327 is a great SBC choice in a 914. Good power, no...   Oct 18 2017, 08:58 PM
Cracker   Welcome to the World of fun 914's Kent...nothi...   Oct 19 2017, 04:26 AM
76-914   327 is a great SBC choice in a 914. Good power, n...   Oct 19 2017, 07:53 AM
Andyrew   I had 225's on mine as well, even had 275...   Oct 19 2017, 09:23 AM
whitetwinturbo   :popcorn: ..and who makes that "better" ...   Oct 21 2017, 08:22 AM
76-914   :popcorn: ..and who makes that "better...   Oct 21 2017, 09:02 AM
76-914   I'm working on "how to" use the exis...   Oct 22 2017, 05:15 PM
76-914   Finally got a chance to work on Red today. Finishe...   Oct 28 2017, 09:40 PM
76-914   Made the rough cut templates out of cardboard. The...   Nov 2 2017, 08:23 PM
76-914   The side will get a trim flange to fill the void o...   Nov 2 2017, 08:27 PM
Andyrew   Looks good!!!   Nov 2 2017, 08:40 PM
bulitt   :trophy:   Nov 3 2017, 05:15 AM
rhodyguy   Kent, contact TC914-8 (tony) about the carb linkag...   Nov 3 2017, 09:11 AM
76-914   Thx Andrew and Bob. When I peel back that protecti...   Nov 3 2017, 05:33 PM
76-914   Good eye Mark. I totally missed that. Now where wa...   Nov 8 2017, 10:10 PM
Blue6   :cheer:   Nov 8 2017, 10:43 PM
Larmo63   Damn, Kent. That looks pretty good. I have to get ...   Nov 8 2017, 11:19 PM
rhodyguy   Fast work Kent! Carry on.   Nov 9 2017, 07:51 AM
76-914   Got'a keep moving if I want to sell this thing...   Nov 9 2017, 08:50 AM
Andyrew   A chemical might help remove it. There might be so...   Nov 9 2017, 09:33 AM
bulitt   It was a temp install to transport the car 2500 mi...   Nov 9 2017, 03:59 PM
Chris914n6   I usually just use a wire brush by hand and my thu...   Nov 9 2017, 03:59 PM
76-914   Yeah Chris, When I get after it I will remove that...   Nov 9 2017, 08:09 PM
914forme   3M adhesive earser wheel   Nov 9 2017, 08:39 PM
76-914   That's it Stephan. But it's about 3/16...   Nov 9 2017, 10:16 PM
bulitt   Wire wheel for a dremel?   Nov 10 2017, 06:10 AM
76-914   Wire wheel for a dremel? Yea Bob, I'm thinki...   Nov 10 2017, 08:41 AM
914_teener   Wire wheel for a dremel? Yea Bob, I'm think...   Nov 10 2017, 08:45 AM
76-914   Delete that Rob. I don't want her to see that....   Nov 25 2017, 06:05 PM
76-914   Since I have this huge mass of cast iron I added a...   Nov 25 2017, 06:41 PM
bulitt   Isn't this car running yet? :D Great Job Ke...   Nov 26 2017, 09:18 AM
76-914   It is now but there is still a lot to do. :beer2:...   Dec 11 2017, 06:27 PM
ValcoOscar   It is now but there is still a lot to do. :beer2...   Dec 11 2017, 08:08 PM
bulitt   Woo Hoo! Can't tell if you hooked up the ...   Dec 11 2017, 08:42 PM
Cracker   Way to go Kent!!! :beer2: :trophy:...   Dec 11 2017, 08:50 PM
bulitt   Way to go Kent!!! :beer2: :trophy...   Dec 11 2017, 08:53 PM
Cracker   I remember that now...long time ago! Cool. To...   Dec 11 2017, 08:59 PM
Andyrew   Mmmm Torque, glorious torque!!! Congra...   Dec 12 2017, 07:08 AM
sb914   Nice job ! :Qarl:   Dec 12 2017, 07:17 AM
bulitt   7hCf3HRTc84   Dec 12 2017, 07:43 AM
rhodyguy   Do you need another horn pad?   Dec 12 2017, 08:15 AM
Larmo63   Sounds great so far....!!!!!...   Dec 12 2017, 07:36 PM
76-914   Thanks guys. The growl raised my testosterone leve...   Dec 12 2017, 09:19 PM
burton73   Thanks guys. The growl raised my testosterone lev...   Dec 13 2017, 12:44 PM
76-914   Thanks guys. The growl raised my testosterone le...   Dec 13 2017, 06:34 PM
914350   I love the way you mounted the radiator. The shrou...   Dec 13 2017, 11:18 AM
76-914   I love the way you mounted the radiator. The shro...   Dec 13 2017, 06:31 PM
Cracker   I believe it is way too early to determine value.....   Dec 13 2017, 07:13 PM
burton73   I believe it is way too early to determine value....   Dec 13 2017, 07:58 PM
Cracker   Ok. With that logic...why stop at 4x? Kent - go fo...   Dec 13 2017, 08:03 PM
76-914   Who knows? I certainly don't. The interior sho...   Dec 14 2017, 09:13 AM
Andyrew   A sorted v8 car in good condition is between 10-15...   Dec 14 2017, 09:27 AM
Cracker   Anyone wanting a radio in that car should not be a...   Dec 14 2017, 09:41 AM
burton73   Anyone wanting a radio in that car should not be ...   Dec 14 2017, 10:32 PM
Chris914n6   Anyone wanting a radio in that car should not be ...   Dec 16 2017, 03:35 PM
Mueller   Anyone wanting a radio in that car should not be ...   Jan 4 2018, 11:51 AM
rhodyguy   :agree: don't fret about a radio.   Dec 14 2017, 10:07 AM
76-914   So I'm killing time waiting on the mufflers to...   Dec 14 2017, 07:16 PM
76-914   I've decided to complete this 914 w/o a radio....   Dec 16 2017, 07:40 PM
Chris914n6   I've decided to complete this 914 w/o a radio...   Dec 16 2017, 08:57 PM
76-914   Thx Chris. I've since discovered that 914rubbe...   Dec 19 2017, 09:22 PM
76-914   I don't know how people get anything done on t...   Jan 4 2018, 11:32 AM
Cracker   Great idea Kent - great Dad!!! I hope ...   Jan 4 2018, 11:54 AM
76-914   Great idea Kent - great Dad!!! I hope...   Jan 4 2018, 09:00 PM
bulitt   I don't know how people get anything done on ...   Jan 4 2018, 07:34 PM
Chris914n6   I don't know how people get anything done on ...   Jan 4 2018, 09:36 PM
rhodyguy   Nice. Don't forget to add transport to the p...   Jan 4 2018, 12:16 PM
914forme   :headbanger:   Jan 4 2018, 09:34 PM
76-914   :headbanger: Oh yea, I forgot your in that tribe...   Jan 5 2018, 11:34 PM
get off my lawn   About a million years ago I was at Irwindale racew...   Jan 8 2018, 06:29 PM
76-914   About a million years ago I was at Irwindale race...   Jan 13 2018, 10:20 PM
bulitt   Wow! Great job!   Jan 14 2018, 06:09 AM
76-914   Thx Bob.Wow, I just realized I forgot to mention t...   Jan 14 2018, 10:44 AM
Cracker   Good for you Kent... When the "hand-off...   Jan 14 2018, 11:01 AM
76-914   Good for you Kent... When the "hand-off...   Jan 14 2018, 11:19 AM
76-914   I forgot to add these pic's once I closed up t...   Jan 14 2018, 01:39 PM
mepstein   Very clean looking. Is that an RH setup?   Jan 14 2018, 01:49 PM
Mueller   Nice radiator setup...might want to add a bead or ...   Jan 14 2018, 02:31 PM
dakotaewing   Try some Denatured alcohol to the cover to remove ...   Jan 14 2018, 05:42 PM
rhodyguy   Nice work Kent.   Jan 14 2018, 06:00 PM
76-914   Very clean looking. Is that an RH setup? Don...   Jan 15 2018, 09:19 AM
- Lo-Fi Version Time is now: 5th September 2025 - 05:09 AM
