FS Heater Flapper Boxes, J tubes, Warm air tubes, Just in time for Summer ! |
bdstone914 |
Jun 22 2017, 09:22 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have two pair of heater boxes that were blasted and powder coated. Some gaskets in the discs survived but most trapped rust under them and were removed. I doubt the gaskets really did much. I would like to sell them as pairs. Asking $100 for a pair plus $15 shipping. New Dansk are $145 each and have the lever oriented wrong.
Also one pair of J tubes. $ 40 and a pair of warm air tubes that come off of the heat exchangers and connect to the flapper boxes. $40 for the pair. I you want the whole bundle I will do $150. Bruce Attached thumbnail(s) |
malcolm2 |
Nov 2 2017, 07:37 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
I have a few spares and I tried to get in there and clean them up, but like the HE it seems that they are designed to be closed once and never entered again.
I only assume that is where it is coming from, but summer driving on the interstate.... 3500+ RPM and my right foot is ON FIRE. I can put my hand under the dash and find the heat vent and there is heat coming out. When I had the flapper on the bench, I put a ring of silicone around the flapper plate that closes on the heat tube. It helped a little. I doubt the MUD in the picture above helped much. |
bdstone914 |
Nov 3 2017, 06:31 AM
I have a few spares and I tried to get in there and clean them up, but like the HE it seems that they are designed to be closed once and never entered again. I only assume that is where it is coming from, but summer driving on the interstate.... 3500+ RPM and my right foot is ON FIRE. I can put my hand under the dash and find the heat vent and there is heat coming out. When I had the flapper on the bench, I put a ring of silicone around the flapper plate that closes on the heat tube. It helped a little. I doubt the MUD in the picture above helped much. Interesting. Was the spring that keep the two flaps spread intact? The air pressure from the engine should also be pushing it closed so I wonder if something else was going on there. What did the left side flapper look like ? I would think that a silicone bead would seal it air tight. BTW I soak them for days in Exaporust to dissolve the crud inside them have them blasted and coated. The one above the clean outside but crusty inside |
Lo-Fi Version | Time is now: 28th May 2024 - 09:07 PM |
