| forrestkhaag |
Oct 24 2017, 09:16 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Out of the blue my recent 6 build died. Here are the facts as I recall them...
Early one morning recently i decided to drag my car to our place in Scottsdale to do some desert driving as I am sick of the traffic in OC. I started the car as usual and drove it to the back of my tow vehicle. I hooked up the towbar and aux. lights (no attached to the 914's electricals)..... As I made my way towing the 914 up the grade up on the I-10 outside of Redlands, the serpentine belt and pulley gave out on the MBZ and proceeded to leave me going 65 in lane 3 of 5 surrounded by semi's and other vehicles that did not want to let me get to the shoulder. As i muscled the no-power steering and no-brakes conundrum toward the shoulder, the car spewed fluids all over the windshield because, by this time, a piece of the pulley went thru the radiator and windshield washer resivoir trashing them along the way to a fried engine. I managed to get to the shoulder and calledthe car and A,.... then called AA then AAA............ Eventually Gomer and the flat bed showed up and picked up the dripping ML. He then headed back to Laguna while I prepared to drive the 914 behind him back home. POPwrrrrrwrrrwrrrrwrrrrwrwrwrwrrrr,... (IMG:style_emoticons/default/WTF.gif) POPwrrrrrwrrrwrrrrwrrrrwrwrwrwrrrr,... (IMG:style_emoticons/default/WTF.gif) Dead............Plenty of turnover but no spark / or should I say one spark then no spark.. (IMG:style_emoticons/default/WTF.gif) For the first time in 3000 miles+, the 914 would not start. Normally 1st crank and it explodes into a nice roar then back to idle... Not this time. Nothing. Zero. Zilch. Keep in mind, I drove the car to the back side of the tow vehicle quite fine. Towing it croaked it? (IMG:style_emoticons/default/WTF.gif) So I called AA then AAA again.... and low and behold, the same driver and truck came back to hitch my 914 to the back of the flatbed that had my toasted MBZ on it. Long story but a longer day on the side of the freeway........... Now the 914 is in AZ dead as a doornail. My pal Keith and I did much trouble shooting on the wiring / this,.. between the two transmissions that went into and one out of his car in the meantime. All leads from the MSD plug to the P.K. wiring harness (that has been flawless for the past several thousand mile of seamless spark) show continuity. the coil is good to go - as proven by exchanging Keiths with mine and mine with keith's... His car runs mine doesnt. We performed several Parts Classic tests to prove that the distributor is good and not fouled in any internal way. I replaced the 85 dollar little green wire (Pelican Parts... ridiculous (IMG:style_emoticons/default/WTF.gif) ) then replaced the coil wire with another MSD unit with the "Power Tower" to allow a standard coil to mate to MSD proprietary wire ends.... another (IMG:style_emoticons/default/WTF.gif) anyway,... One of the MSD Tech guys was a smartass smug dipsey doodle talking down at Keith and I - and the second guy from MSD Tech that both Keith and I talked to (Joe) was a complete professional in style and manner of presenting a few tests to eliminate the coil and the distributor (ahhhgen...) So my simple question for the folks out there is.. Has anyone with the MSD Digital AL6 experienced this kind of DOA mystery? the hills and mountain roads leading to the Grand Canyon are begging for an answer. The simple way to add a week to no driving is to pack up the box and send it to MSD for a test / and I will do that if no sage advice comes from this lengthy narrative.. but there is always the hope (unfortunately).. that one of you guys has seen this issue before me and can relay some sage advice. (IMG:style_emoticons/default/beerchug.gif) Attached image(s)
| forrestkhaag |
Nov 5 2017, 02:24 PM
Thanks to all for the support and information along the way to a solution. As w/ PorscheTub and others, the MSD box simply croaked. Not while driving but maybe when first starting to turn over the motor on the side of the freeway some weeks back when the ML Benz toasted its engine and totaled it life.
In any case, Joe at MSD apologized for a miscomm in the RMA department. (in the return) and he rushed overnight out a new AL6 Digital version new in box with all of the associated parts, new harness, etc. It was plug and play / but........... I fubared the reinsertion of the dizzy by one gear tooth so performance, although running, was horrible / then off to determine the correct gear alignment on the dizzy R&I and VAROOM! The little beast is back to full power at all ranges of RPM. Now that I am up and running in Scottsdale for the winter, I will have to learn the nz and outz of weekend drives and meets / or organize one or two. Cheers and thanks again for the support. (IMG:style_emoticons/default/beerchug.gif) Attached image(s)
forrestkhaag DEAD ON ARRIVAL Oct 24 2017, 09:16 AM
Cairo94507 Oh man - sorry to hear that story X2. I hope you ... Oct 24 2017, 09:24 AM
drem914 Hang in there Forrest. I know you will get this so... Oct 24 2017, 09:54 AM
forrestkhaag Thanks Guys! Today I am going to take the ent... Oct 24 2017, 10:13 AM
Steve That sucks!! Sorry to hear this. Positiv... Oct 24 2017, 10:19 AM
BeatNavy Forrest has in spades what every 914-owner needs: ... Oct 24 2017, 10:32 AM
worn
Forrest has in spades what every 914-owner needs:... Oct 24 2017, 02:47 PM
Coondog Sorry Forrest, was wondering where you have been. ... Oct 24 2017, 10:41 AM
forrestkhaag That stretch of highway has more potholes, pothead... Oct 24 2017, 02:20 PM
914_teener
That stretch of highway has more potholes, pothea... Oct 24 2017, 05:16 PM
Justinp71
That stretch of highway has more potholes, pothea... Oct 27 2017, 03:16 PM
Elliot Cannon That much trouble almost sounds like the "sub... Oct 24 2017, 03:34 PM
michael7810 Damn Forrest, that sucks. I have a 6AL on my TIV ... Oct 24 2017, 04:04 PM
snakemain Does yours have the LED that blinks when it first ... Oct 24 2017, 04:11 PM
76-914 This is easy. The 914 went into shock as they are ... Oct 24 2017, 04:50 PM
Elliot Cannon
This is easy. The 914 went into shock as they are... Oct 24 2017, 09:33 PM
worn
This is easy. The 914 went into shock as they ar... Oct 25 2017, 12:39 PM
76-914
This is easy. The 914 went into shock as they ar... Oct 26 2017, 08:40 AM
Jeff Hail What kind of pick up are you using as a trigger? M... Oct 24 2017, 07:12 PM
mb911 I had that problem on a twin plug setup on my 3.2 ... Oct 24 2017, 07:21 PM
plays with cars Have you gone through the basics? Fuel, spark, co... Oct 24 2017, 08:35 PM
zipedadoo You might try disconnecting the tachometer. I chas... Oct 24 2017, 08:36 PM
euro911 I feel for ya, Forrest. 'Eileen' (Westfali... Oct 24 2017, 11:30 PM
jkb944t Sorry to hear about your streak of bad luck.
My -... Oct 25 2017, 10:41 AM
Steve It’s also a double negative to tow a German car ... Oct 25 2017, 01:03 PM
altitude411
It’s also a double negative to tow a German car... Oct 25 2017, 07:06 PM
DM_2000 Hook up a AC volt meter or oscilloscope to the dis... Oct 25 2017, 04:03 PM
jim_hoyland Good luck on this one; when I previously ran MSD, ... Oct 25 2017, 04:29 PM
worn
Good luck on this one; when I previously ran MSD,... Oct 25 2017, 05:42 PM
jim_hoyland
Good luck on this one; when I previously ran MSD... Oct 26 2017, 05:58 AM
porschetub Seems a few folks have had issues with them and ma... Oct 25 2017, 06:08 PM
whitetwinturbo tow the MB with the 914 :evilgrin: :evilgrin: :... Oct 25 2017, 09:04 PM
Justin Fischer I had an MSD die on me while driving one day, like... Oct 25 2017, 09:52 PM
forrestkhaag Thanks for the advice guys / MSD has agreed to tak... Oct 27 2017, 10:11 AM
76-914
Thanks for the advice guys / MSD has agreed to ta... Oct 27 2017, 03:05 PM
forrestkhaag update: At 4pm MST today, MSD acknowledged that t... Nov 2 2017, 07:30 PM
porschetub They are f ing with you Forrest that's why I m... Nov 2 2017, 10:32 PM
Steve Great news!! Missed you this weekend at t... Nov 5 2017, 02:56 PM
euro911 Run Forrest, run ...
:thumbsup: Nov 5 2017, 05:08 PM
forrestkhaag Uhoh...................
I was driving along heade... Nov 10 2017, 02:01 PM
76-914 :poke: Eat a few more of those type breakfast a... Nov 10 2017, 02:28 PM
Jeff Hail
:poke: Eat a few more of those type breakfast ... Nov 10 2017, 06:58 PM
Larmo63 Does MSD stand for Multi Situational Disfunction?
... Nov 10 2017, 07:55 PM
porschetub
Does MSD stand for Multi Situational Disfunction?... Nov 10 2017, 08:28 PM
914_teener Forrest is not meant to die. :Qarl: Nov 10 2017, 08:13 PM
Elliot Cannon None of us will die. It's only a transition. ... Nov 10 2017, 08:18 PM
914_teener Nice seeing you at the G&R Ellyut. Nov 10 2017, 08:24 PM
forrestkhaag MSD M ine S imply D oesn't...........
MSD M ... Nov 14 2017, 12:05 PM
98101 I’m not even into boats, but this one is beautif... Nov 25 2017, 07:49 PM
porschetub
I’m not even into boats, but this one is beauti... Nov 25 2017, 08:20 PM
98101
HHHmmm your car has no power steering or power br... Nov 25 2017, 09:08 PM
Steve There’s water in the desert?
Glad your car is ru... Nov 14 2017, 03:15 PM
Larmo63 Ellyut gave me a 914 toy car at the G & R.
I ... Nov 14 2017, 06:06 PM
porschetub
I... Nov 14 2017, 06:41 PM
Perry Kiehl Good to know it wasn't on me, whew!
Pleas... Nov 25 2017, 07:23 PM
forrestkhaag And Steve: Flat Water in the desert lakes and bi... Nov 27 2017, 06:17 PM
forrestkhaag And just as an update......... The newly replaced ... Dec 16 2017, 05:02 PM
colingreene Thats why we have a spare for the race car on hand... Dec 16 2017, 09:45 PM
jim_hoyland I ran two MSDs; both wired to a switch so that eit... Dec 17 2017, 07:57 AM
forrestkhaag Hey Jim: Thanks and the fact that MSD would sell ... Dec 18 2017, 06:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th September 2026 - 05:41 PM |
