Newbie fueling question |
87m491 |
Nov 10 2017, 07:54 AM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
As usual I have shot my own self in the foot and have a self inflicted "ran when parked" scenario. In the summer of 2016 I pulled a 74 2.0 with stock fuel injection out of a fairly long slumber and drove it a few hours home. After being pleasantly surprised at how well it seemed to run I proceeded to pull out the interior for sprucing up (still out) and redid wheels, brake system, wheel bearings and made my way to the fuel system.
The tank was amazingly clean so new tank sock, filter, updated style pump was already in the frunk, so new hoses, tangerine SS lines stem to stern and all new engine compartment lines, reconditioned injectors, yada, yada. Fast forward to refire time and not so much. It's tough to confirm working FP from the drivers seat so I hard wired it and still no start. (starter is turning the engine fine) With all of the lines out at once I thought there was a better than even money chance I swapped fuel in and out. I swapped lines in the engine bay and was met with a powerful suction whoosh when I disconnected one. I hard wired the FP again and heard the fuel swirling around the tank I assume from the return so now that seems good. I also have spark from the coil and as I type this I can't believe I forgot to check from the cap out, DOH! Short question long, is the FP supposed to run with the key on or is it keyed to engine speed etc? Also with the interior and "convenience" electricals out, might I have disconnected something that it is keeping the car from firing up? thx Mike |
Boomingbeetle |
Nov 10 2017, 10:25 AM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
Pump is supposed to be on only with key in “on” position. Do you have a power probe or multi meter to verify power at the coil or a spark tester at the plug? Although unlikely, there’s no chance it is an after market pump that you reveresed the in and out flow, or left a set of vise-locks on the line someplace?
87m491 |
Nov 10 2017, 10:30 AM
Thanks, as noted power from the coil, but I didn't check to the plugs. will do this weekend. So far seems the pump only supposed to see steady power when a sensor "sees" engine RPMs, a safety feature to make sure the pump isn't working away after a cars been in an accident or similar..
Pump is supposed to be on only with key in “on” position. Do you have a power probe or multi meter to verify power at the coil or a spark tester at the plug? Although unlikely, there’s no chance it is an after market pump that you reveresed the in and out flow, or left a set of vise-locks on the line someplace? |
Spoke |
Nov 10 2017, 01:26 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Thanks, as noted power from the coil, but I didn't check to the plugs. will do this weekend. So far seems the pump only supposed to see steady power when a sensor "sees" engine RPMs, a safety feature to make sure the pump isn't working away after a cars been in an accident or similar.. The sensor which "sees" engine RPM are the extra contact switches on the distributor which also fires the injectors. Once the distributor starts rotating, full time power is applied to the fuel pump. |
Lo-Fi Version | Time is now: 7th June 2024 - 07:12 PM |
