Steering Shaft, Feedback / Update |
jim_hoyland |
Oct 19 2017, 10:53 AM
Get that VIN ? Group: Members Posts: 9,306 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
When drive 10-15 mph on a local street that's not newly paved I get feedback up the steering shaft. It sounds like something is not tight. The steering wheel end has little play and the car has new shocks.
Any thought on where I should be looking ? 11/13/17 Update: turned out to be the top nut on the new Bilsteins was not tight, |
Steve |
Nov 14 2017, 09:36 AM
914 Guru Group: Members Posts: 5,594 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Interesting... I had a knock coming from the front suspension, when I hit an uneven corner, speed bump, etc. I thought it was something in the sway bar. Took a lot of crap apart to find out the top nut was also loose on the top of my strut. I think the washer is supposed to be bent up to prevent the nut from moving. Both of my washers were flat. After torquing the nuts, i bent the washer up on both nuts, so it doesn't happen again.
Lo-Fi Version | Time is now: 22nd May 2024 - 10:47 PM |
