> Fuel Pump for Carbs, Fuel Pump
simonjb
post Nov 20 2017, 09:25 AM
KiwiMan
I was wondering what fuel pump folks are using and like for a Carb conversion. Engine is a 2.0 upgraded to 2.3 with two Weber 44 IDF carbs.
Spoke
post Nov 20 2017, 09:31 AM
Jerry
I'm using Mr. Gasket 12s on my 2056.
12s
simonjb   Fuel Pump for Carbs   Nov 20 2017, 09:25 AM
Spoke   I'm using Mr. Gasket 12s on my 2056. 12s   Nov 20 2017, 09:31 AM
theer   Tangerine sells everything you need (see fuel pump...   Nov 20 2017, 09:35 AM
michael7810   Tangerine sells everything you need (see fuel pum...   Nov 20 2017, 01:29 PM
GeorgeRud   Low pressure Pierburg pump mounted up front by the...   Nov 20 2017, 09:48 AM
porschetub   Low pressure Carter pump mounted on front crossmem...   Nov 20 2017, 01:35 PM
SirAndy   I seem to remember the same pump comes from CB per...   Nov 20 2017, 01:55 PM
porschetub   I seem to remember the same pump comes from CB pe...   Nov 20 2017, 10:21 PM
thelogo   I seem to remember the same pump comes from CB pe...   Nov 20 2017, 11:23 PM
North Coast Jim   I seem to remember the same pump comes from CB pe...   Nov 21 2017, 09:02 AM
Mark Henry   You can buy a PMO fuel pressure regulator and run ...   Nov 20 2017, 04:41 PM
forrestkhaag   Sir Andy's pump as illustrated is the one I ha...   Nov 20 2017, 05:49 PM
sportlicherFahrer   Running that same Carter pump from CB Performance ...   Nov 20 2017, 06:14 PM
SirAndy   And i forgot, whatever you do, please don't ha...   Nov 20 2017, 06:45 PM
simonjb   Thanks guys !   Nov 20 2017, 08:26 PM
Tbrown4x4   I really need to do a write-up on this. PO put a F...   Nov 21 2017, 04:32 AM
Racer Chris   When you key up, the pump runs for 3 seconds to p...   Nov 21 2017, 07:43 AM
Mark Henry   For power, I installed one of these: [url=http...   Nov 21 2017, 10:12 AM
- Lo-Fi Version Time is now: 4th June 2025 - 04:15 PM
