Friday, 8 August 2025
> Fuel Pump for Carbs, Fuel Pump
simonjb
post Nov 20 2017, 09:25 AM
KiwiMan
I was wondering what fuel pump folks are using and like for a Carb conversion. Engine is a 2.0 upgraded to 2.3 with two Weber 44 IDF carbs.
porschetub
post Nov 20 2017, 01:35 PM
Low pressure Carter pump mounted on front crossmember,not too loud, fairly priced and runs well.
I seem to remember the same pump comes from CB performance also.
post Nov 20 2017, 01:55 PM
Resident German
QUOTE(porschetub @ Nov 20 2017, 11:35 AM) *
CB Performance has a rotary low pressure pump with filter, that's what i ran on my 2056.
http://www.cbperformance.com/product-p/3193.htm
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1511207757.1.jpg)
Friends don't let friends use facet pumps ...
(IMG:style_emoticons/default/barf.gif)
North Coast Jim
post Nov 21 2017, 09:02 AM
QUOTE(SirAndy @ Nov 20 2017, 02:55 PM) *
I also run this setup but I purchased mine form Tangerine Racing. Also bought the SS fuel line for Carbs. Used the remaining grommet holes to run the wiring thru the tunnel. Bought a 2 wire multi stranded and flat jacketed wire from West Marine. Mounted the pump/filter combo under the gravel pan. It's tight but it works. Happy to see the pump outside of the car and the pressure line now in SS tube. As insurance I installed on the top of the engine a fuel regulator. I actually use a 2.5lb pressure with 40IDFs on a 2.1L engine. Runs great.
simonjb   Fuel Pump for Carbs   Nov 20 2017, 09:25 AM
Spoke   I'm using Mr. Gasket 12s on my 2056. 12s   Nov 20 2017, 09:31 AM
theer   Tangerine sells everything you need (see fuel pump...   Nov 20 2017, 09:35 AM
michael7810   Tangerine sells everything you need (see fuel pum...   Nov 20 2017, 01:29 PM
GeorgeRud   Low pressure Pierburg pump mounted up front by the...   Nov 20 2017, 09:48 AM
porschetub   Low pressure Carter pump mounted on front crossmem...   Nov 20 2017, 01:35 PM
SirAndy   I seem to remember the same pump comes from CB per...   Nov 20 2017, 01:55 PM
porschetub   I seem to remember the same pump comes from CB pe...   Nov 20 2017, 10:21 PM
thelogo   I seem to remember the same pump comes from CB pe...   Nov 20 2017, 11:23 PM
North Coast Jim   I seem to remember the same pump comes from CB pe...   Nov 21 2017, 09:02 AM
Mark Henry   You can buy a PMO fuel pressure regulator and run ...   Nov 20 2017, 04:41 PM
forrestkhaag   Sir Andy's pump as illustrated is the one I ha...   Nov 20 2017, 05:49 PM
sportlicherFahrer   Running that same Carter pump from CB Performance ...   Nov 20 2017, 06:14 PM
SirAndy   And i forgot, whatever you do, please don't ha...   Nov 20 2017, 06:45 PM
simonjb   Thanks guys !   Nov 20 2017, 08:26 PM
Tbrown4x4   I really need to do a write-up on this. PO put a F...   Nov 21 2017, 04:32 AM
Racer Chris   When you key up, the pump runs for 3 seconds to p...   Nov 21 2017, 07:43 AM
Mark Henry   For power, I installed one of these: [url=http...   Nov 21 2017, 10:12 AM
- Lo-Fi Version Time is now: 7th August 2025 - 09:12 PM
