Tranny leaks, Out of car |
newdeal2 |
Nov 6 2004, 06:18 PM
Unregistered |
I am getting ready to install my rebuilt engine and want to find leaks in the tranny. I replaced the reverse switch [it was leaking for sure] and I am planning to replace the shift shaft seal.
Is there a good way to test for other leaks, say put in tranny oil and let it sit? |
Joe Ricard |
Nov 6 2004, 07:55 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
If you didn't replace input and output seals you may find out the hard way where the transaxle is leaking. the input seal will soak the clutch with oil. PITA and WALLET to not do this inexpensive job. Speedometer O-ring also. Cheap and easy but will make a mess on the exhaust which will stink to high heaven.
Lo-Fi Version | Time is now: 9th June 2024 - 09:11 PM |
