Another GB from 914rubber.com - Bet you cant break these. SOLID STAINLESS, Rear trailing arm Bushings and support rod $120 for the set |
Mikey914 |
Nov 30 2017, 10:59 AM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Having the experience of rebuilding Matt's barn find, we noticed that there was rust around the edges of the tubes that went through the control arms. After cleaning these up we noticed that these were constructed from hollow tubes that had a plate with a bolt end welded on. The welds had not been cleaned up well and rust had pitted the them and allowed for water penetration actually allowing the inside of the tube to rust.
We made replacement simple. Machining the new tubes from stainless steel they will never be able to rust and fail. Once we had the center shafts ready we made the bushings from rubber just like factory. These proved difficult to install, so we switched this up to poly-graphite and they we much easier to install. So our "kit" comprises 2 - solid stainless steel pivot shafts, and 4 poly-graphite bushings. I have 2 other GBs I'm about to post - The front strut top rubber replacement The A arm bushings - with or without special tools to install Attached thumbnail(s) |
Mikey914 |
Nov 30 2017, 11:57 AM
To answer the Question on these bushings.
1- No squeak these are actually a self lubricating bushing and you will note a "oily" residue on them. One of the reasons we went this way was because they are actually easier to install being self lubricating. 2-Durometer is slightly higher than OEM. This is because of the graphite. Matty is currently running these on his car and he's been happy with the ride. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:24 PM |
