Using a 911 oil pressure/temp gauge. |
falcor75 |
Dec 1 2017, 12:12 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Those of you who use the 911 pressure gauge how did you fit the sensors?
It looks like the temp sensor will be a straight fit for the stock on on the bottom of the engine but I havnt tried the threads yet. I've got a gauge from a '79 911 and the pressure sensor had a way bigger threaded connector than I expected, something like an M18x1,5 or so. Anyone using the same and how did you connect it? |
914forme |
Dec 2 2017, 08:34 AM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Draft 42 has a nice extensions for just such a place also.
It has the proper M10 fittings, and on the head end has both M10 and 1/8 NPT fittings for a proper leak free fitting. And then you just add the proper VDO sender in either 1/8 NPT or M10. An M18, never seen one that large, please post a picture. Does it actually have a PN, that looks like a Porsche or VW P/N |
Lo-Fi Version | Time is now: 23rd May 2024 - 09:22 AM |
