Using a 911 oil pressure/temp gauge. |
falcor75 |
Dec 1 2017, 12:12 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Those of you who use the 911 pressure gauge how did you fit the sensors?
It looks like the temp sensor will be a straight fit for the stock on on the bottom of the engine but I havnt tried the threads yet. I've got a gauge from a '79 911 and the pressure sensor had a way bigger threaded connector than I expected, something like an M18x1,5 or so. Anyone using the same and how did you connect it? |
falcor75 |
Dec 2 2017, 01:47 PM
Yes I'm planning on routing a hose from the case to a T-fitting or getting a sender with both the light and gauge connectors. Just need to find out what senders match my gauge... My gauge has a blue stamp on the back staying "986 5.79" which I interpreted as may 1979.....
porschetub |
Dec 2 2017, 02:36 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yes I'm planning on routing a hose from the case to a T-fitting or getting a sender with both the light and gauge connectors. Just need to find out what senders match my gauge... My gauge has a blue stamp on the back staying "986 5.79" which I interpreted as may 1979..... I have always matched the senders to the max of the gauges,I tested mine for accuracy with new 52mm VDO gauges I had and found them to be very close to my 911 one. You may have an issue matching the 911 gauge as I don't believe the T4 generates as much oil pressure...I don't really know to be honest but it could be out of range (IMG:style_emoticons/default/confused24.gif) ,there was a 911 pressure gauge insert that read 5 bar max but I don't recall what MY 911 that was on. |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:16 AM |
