| 7TPorsh |
Dec 1 2017, 11:39 AM
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California
So as the weather gets cold again, I realize that with my increasing age I need to do something about heat in the 914 if i want to drive it comfortably.
I'm running a header and most all the ducting on the car has been pulled out. I've been researching all the threads on here about electric heaters and the Webasto heaters, etc.....I found this! Thinking I can maybe mount inside or in place of the cowl airbox and run a couple hose into the cabin. What y'all think? |
| Mark Henry |
Dec 3 2017, 08:02 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I purchased an old Eberspacher gas-fired heater to install in my conversion car. It could be done, but I eventually went with heat exchangers as I know they’ll bake you in a -6 if properly working. Now that they’re available through Porsche for the -6 (or some beautiful stainless ones through mb911), I don’t know if it’s worth the hassles of designing and installing a gas or diesel heater. Used SSIs are seen often enough for the -4s as well (though do need to be tested for cracks). There are photos of a system installed in the front trunk of a 914, but I’ve never heard of anyone that actually has seen one. No matter what system you choose, be sure to keep a CO detector in the car as any leaks could kill you. I had a friend that had a brother get killed in a motor home from a heater. Went to sleep and never woke up. Family was never the same. Bob B Aircraft Spruce sells a little button CO2 sensor that you can stick right in the center of your tach. They only last 18 months from opening the pack, but they're something like $7 each. If you sleep in your car you want something with an alarm. Leaking heater box can kill you just as fast as a gas heater. Likely won't kill you in a moving 914, the top leaks too much, but CO2 poisoning is a bitch. |
7TPorsh Diesel Cabin Heater Dec 1 2017, 11:39 AM
johnhora Gary...
That's an interesting unit...
sort of ... Dec 1 2017, 02:14 PM
SirAndy Why not get a modern Eberspächer unit that runs o... Dec 1 2017, 02:33 PM
ConeDodger
Why not get a modern Eberspächer unit that runs ... Dec 2 2017, 02:59 PM
Mark Henry It can be used but I don't think like you said... Dec 1 2017, 02:33 PM
7TPorsh
It can be used but I don't think like you sai... Dec 1 2017, 03:15 PM
bbrock
or maybe in the rear or engine bay then tapped i... Dec 1 2017, 04:29 PM
7TPorsh I like the price compared to the Eberspächer. I a... Dec 1 2017, 03:13 PM
Mark Henry
I like the price compared to the Eberspächer. I ... Dec 2 2017, 10:52 AM
porschetub
I like the price compared to the Eberspächer. I... Dec 2 2017, 12:14 PM
7TPorsh Looky looky....5K / 4 outlet
Dec 1 2017, 03:21 PM
jd74914
It would be interes... Dec 4 2017, 12:39 PM
theer Either would be very interesting for non-air-coole... Dec 1 2017, 04:01 PM
Mueller
Either would be very interesting for non-air-cool... Dec 1 2017, 04:19 PM
thelogo Dude your in la canada
Not o canada
Put o... Dec 2 2017, 09:43 AM
GeorgeRud I purchased an old Eberspacher gas-fired heater to... Dec 2 2017, 10:18 AM
burton73
I purchased an old Eberspacher gas-fired heater t... Dec 2 2017, 07:40 PM
Montreal914 Replace your header for a Tangerine header with he... Dec 2 2017, 02:49 PM
Rand You don't need Andy to answer that.
https://ww... Dec 2 2017, 03:18 PM
[url=http... Dec 2 2017, 03:23 PM
ConeDodger Yes, I did google that before I asked the question... Dec 2 2017, 04:34 PM
timothy_nd28
IUPAC nomenclature states that just a 1 multipli... Dec 4 2017, 12:09 PM
jd74914
IUPAC nomenclature states that just a 1 multipl... Dec 4 2017, 12:32 PM
Wyvern I would go with something like this.
http://www.... Dec 4 2017, 10:57 AM
http://www... Dec 4 2017, 11:33 AM
Mark Henry
[quote name='Wyvern' post='2554771' date='Dec 4 2... Dec 4 2017, 11:58 AM
JmuRiz Even think of just getting some seat heaters and w... Dec 4 2017, 12:50 PM
Even think of just getting some seat heaters and ... Dec 4 2017, 01:56 PM
JRust Heater Ross posted this on FB thread. Looks prett... Dec 4 2017, 02:25 PM
Dr Evil
Heater Ross posted this on FB thread. Looks pret... Dec 4 2017, 02:30 PM
Boomingbeetle I always liked the Stewart-Warner "southwind... Dec 4 2017, 02:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:38 AM |
