Using a 911 oil pressure/temp gauge. |
falcor75 |
Dec 1 2017, 12:12 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Those of you who use the 911 pressure gauge how did you fit the sensors?
It looks like the temp sensor will be a straight fit for the stock on on the bottom of the engine but I havnt tried the threads yet. I've got a gauge from a '79 911 and the pressure sensor had a way bigger threaded connector than I expected, something like an M18x1,5 or so. Anyone using the same and how did you connect it? |
clapeza |
Dec 3 2017, 10:32 AM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
falcor75,
Looks like we're in a similar situation. I'm building a triple gauge. The pressure gauge I have has a date that matches the same sender you pictured - so that's what I got. I'm going to be using the 42DraftDesigns relocation kit, the stock idiot light sender, and a gauge, in addition to a 911 sender. After making the same discovery, looks like I need a different sender. It looks like this sender might work: https://www.vdo-gauges.com/sensors/pressure...psi-m10x1k.html available from: https://www.summitracing.com/ga/parts/vdo-360001 I haven't tried it yet, but it does claim to be compatible with 0-5 bar gauges. |
Lo-Fi Version | Time is now: 23rd May 2024 - 07:26 AM |
