HELP!! Need rocker shaft!!, So That's why it won't run!!!!! |
crash914 |
Nov 6 2004, 04:10 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Found out why my motor won't run correctly, spitting out the intake....
valves were tight on this cylinder... took off the rocker shaft to replace an O-ring...rockers won't move on the shaft???? Turns out the rockers are galled to the shaft!!!! (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/sad.gif) So for sure this was holding the intake valve open.... anyone have a set of rocker shafts? at a minimum I need 1 shaft and 2 rockers...I am running swivel feet so need a 1.7? rocker??? If anyone has a complete set of 8 I will take them all...please contact me ASAP so I can get this monster running.... PM or email to hberwald@stonyfield.com...if you want, you can call to 603.370.1467. thanks! |
crash914 |
Nov 7 2004, 08:13 AM
Hey Mark...the inside of the one I got off was not too bad...the other is stuck tight...time to go to the press......
I still need the shaft!!!???? that does not sound right.... (IMG:style_emoticons/default/ohmy.gif) The rockers were ground to allow for the swivel feet....to fit the geometry with the longer adjusters..... herb |
Lo-Fi Version | Time is now: 23rd May 2024 - 10:54 AM |
