> 73 914 2.0 Rebuild
R Dub
post Dec 3 2017, 02:34 PM
Finally got the car back to IL and started to clean it up. Overall he car is in really good shape. There is virtually no rust on it. Just a very little bit starting to form on the front fender by the hood. The paint is in really good condition but will probably need a new paint job as there are some chips in that that won't be able to touch up since it is 30+ years old. Will need the Recaro seats to be redone and will need a new arm rest. Drained the old gas out of it and then drained the oil which was mostly sludge. Bought sludge remover and put that in the case to help break it up. The mice ate the plug wires and the battery is totally shot. What spark plugs and wires do you guys recommend?
Here are a few picture.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333259.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i582.photobucket.com-21387-1512333260.5.jpg)
Larmo63
post Dec 4 2017, 10:11 PM
Those seats look like Scheels. Are they marked Recaro?
And..... (IMG:style_emoticons/default/welcome.png)
R Dub   73 914 2.0 Rebuild   Dec 3 2017, 02:34 PM
Olympic 914   Slantnose looks nicely done.   Dec 3 2017, 05:07 PM
krazykonrad   :wttc: The general consensus is that the origina...   Dec 4 2017, 09:18 AM
R Dub   :wttc: The general consensus is that the origin...   Dec 4 2017, 11:54 AM
mgphoto   Beru another OEM supplier.   Dec 4 2017, 12:25 PM
The Cabinetmaker   Most folks use ngk plugs and beru wires   Dec 4 2017, 12:44 PM
R Dub   Just bought a set of Beru Wires and Bosch plugs fr...   Dec 4 2017, 03:18 PM
mgphoto   Battery recommendation AGM, no free acid, prevents...   Dec 4 2017, 04:01 PM
R Dub   Battery recommendation AGM, no free acid, prevent...   Dec 4 2017, 04:52 PM
Larmo63   Those seats look like Scheels. Are they marked Rec...   Dec 4 2017, 10:11 PM
burton73   Those seats look like Scheels. Are they marked Re...   Dec 4 2017, 10:49 PM
R Dub   I was told by my dad and Grandpa that they are Rec...   Dec 10 2017, 01:53 PM
R Dub   Update. Actually got the car running to day. First...   Feb 17 2018, 09:17 PM
burton73   It there snow on the ground there. Stay dry my fr...   Feb 17 2018, 10:02 PM
burton73   This is a Konig driver's seat, but sure looks ...   Feb 17 2018, 10:05 PM
R Dub   I looked up you seats and I think they are Koni...   Feb 19 2018, 09:43 AM
Porschef   I've got the same wheel on my car, your horn b...   Feb 18 2018, 08:22 AM
R Dub   I've got the same wheel on my car, your horn ...   Feb 19 2018, 09:44 AM
R Dub   Looking for some parts advice. 1. Right under the...   Feb 19 2018, 09:50 AM
marksteinhilber   Looking for some parts advice. 1. Right under th...   Jan 10 2019, 12:05 PM
fishgeckos   I like the rear spoiler.   Feb 19 2018, 10:06 AM
R Dub   A couple of questions. As I mentions this car does...   Feb 26 2018, 01:01 PM
R Dub   Just a quick update, I found a place in CA called ...   Mar 16 2018, 05:48 PM
R Dub   Haven't posted in a while cause I haven't ...   Jun 19 2018, 12:43 PM
rjames   Haven't posted in a while cause I haven't...   Jun 19 2018, 05:03 PM
rhodyguy   Go to the classic thread forum. The easy method to...   Jun 19 2018, 05:18 PM
R Dub   Got the fuel pump figured out but found out that o...   Nov 11 2018, 07:35 PM
Mblizzard   Got the fuel pump figured out but found out that ...   Nov 12 2018, 10:19 AM
R Dub   You can go the AA Piston route for P/Cs for abou...   Nov 12 2018, 01:49 PM
Mblizzard   [quote name='Mblizzard' post='2664984' date='Nov ...   Nov 13 2018, 11:43 AM
Tdskip   Good morning. Not to discourage your asking quest...   Nov 13 2018, 07:27 AM
TheCabinetmaker   What Td said. Do your search on Google, then add t...   Nov 13 2018, 11:29 AM
bbrock   And make sure you are settled on your fuel system ...   Nov 13 2018, 12:18 PM
R Dub   I'm going to keep the car with the dual Webers...   Nov 13 2018, 04:49 PM
R Dub   Engine out [img]http://www.914world.com/bbs2/uplo...   Jan 9 2019, 07:49 PM
mgphoto   1 motor is no longer stock, if it was then yes l...   Jan 10 2019, 05:21 PM
R Dub   1 motor is no longer stock, if it was then yes le...   Jan 10 2019, 06:39 PM
mgphoto   1 motor is no longer stock, if it was then yes l...   Jan 11 2019, 01:37 PM
R Dub   I built mine with parkerized solid lifters and h...   Jan 12 2019, 05:19 PM
Bleyseng   I built mine with parkerized solid lifters and ...   Jan 27 2019, 04:33 PM
steuspeed   No reason to stick with 2.0L. Go for more power. I...   Jan 9 2019, 08:05 PM
mgphoto   Pull the oil pump, look inside, if the cam gear ha...   Jan 10 2019, 05:04 PM
mgphoto   Hydraulic lifters, bad...   Jan 10 2019, 05:06 PM
bbrock   There are several threads on the swivel foot adjus...   Jan 12 2019, 11:10 PM
R Dub   There are several threads on the swivel foot adju...   Jan 13 2019, 04:24 PM
R Dub   Just found this on aircooled.net about the 911 adj...   Jan 13 2019, 04:43 PM
mgphoto   My advice is that you should pick up the Wilson VW...   Jan 14 2019, 02:16 PM
R Dub   Just ordered about $630 worth of seals from 9...   Jan 27 2019, 03:36 PM
Valy   That crack needs some head welding. Sorry for the ...   Jan 28 2019, 12:00 AM
R Dub   Quick update: The heads are with Adrian at Headfl...   Mar 5 2019, 02:23 PM
R Dub   Starting to get some parts in. I was told the head...   Mar 23 2019, 03:29 PM
R Dub   Dropped the motor off with McMark at Original Cust...   Mar 31 2019, 03:13 PM
R Dub   Got the motor back from McMark a couple weeks ago....   Jun 11 2019, 12:17 PM
R Dub   Update. Put the new relay in and fuel pump seemed ...   Jun 15 2019, 08:53 PM
R Dub   Today was a great day. Got the oil cooler lines al...   Jun 23 2019, 08:57 PM
R Dub   Been two months since I brought the car home. I dr...   Aug 24 2019, 08:57 PM
Larmo63   Your turn signal switch is probably broken or worn...   Aug 25 2019, 06:34 PM
R Dub   Unfortunately the car has been put away for the wi...   Oct 22 2019, 05:24 PM
R Dub   Got the interior torn apart. Now I need some help ...   Dec 24 2019, 12:43 PM
timothy_nd28   Yes, the old light bulbs are not used anymore when...   Dec 30 2019, 01:00 PM
R Dub   Quick update. The interior is at the shop. Seats, ...   Jan 15 2020, 06:18 PM
R Dub   Just picked this up from the interior guy today. T...   Jan 18 2020, 02:31 PM
R Dub   Had some goodies arrive. Got a new Bluetooth head ...   Jan 25 2020, 03:48 PM
R Dub   Got to spend some time on the car today. Got the L...   Jan 26 2020, 07:58 PM
R Dub   Dash is done. And here a little teaser if the seat...   Feb 1 2020, 11:41 AM
R Dub   Seats are done. What a difference. Start to put th...   Feb 28 2020, 09:43 PM
R Dub   Good news and bad news. Good news is got the int...   Apr 26 2020, 08:46 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:59 AM
