Jack stand placement, another question about placement of jack stands |
dh_berman |
Dec 3 2017, 07:12 PM
Newbie Group: Members Posts: 11 Joined: 31-July 17 From: Boston, MA Member No.: 21,305 Region Association: None |
I've read lots of threads here about jack points but I haven't seen anyone comment on this specifically.
Is there any problem with putting jack stands under the rear trailing arms at their pivot points? |
porschetub |
Dec 4 2017, 02:27 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I use the trail arm pivots with thin strips of plywood under the "u" shaped tops,saves marking the paint and my car is very solid on the stands this way.
I only use the jacking points to raise and lower the car,would rather not use these area's for jackstands. Don't try the original jackpoints like I did,I now have to repair one after it broke (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) ,still haven't really worked out to repair it @ this stage. |
Elliot Cannon |
Dec 5 2017, 11:54 AM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I use the trail arm pivots with thin strips of plywood under the "u" shaped tops,saves marking the paint and my car is very solid on the stands this way. I only use the jacking points to raise and lower the car,would rather not use these area's for jackstands. Don't try the original jackpoints like I did,I now have to repair one after it broke (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) ,still haven't really worked out to repair it @ this stage. Those jack points are useless. IMHO Cut them out, fill the hole in your rocker panels and carry a small floor jack to use when you need to change a tire. |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:18 AM |
