> Who has mounted Mikey’s Fender Liners?, 914 Rubber Issue
RickS
post Dec 2 2017, 10:28 PM
Just received the box with the liners. Instead of the stated “clips” for mounting they came with rivets. Clips suggest clipping the liners to the fenders or other attachment points rivets on the other hand... Am a bit hesitant to start drilling holes in my original sheet metal. No instructions were provided either.
Any one done this or have suggestions of the least invasive way they mounted these not using “clips”?
cary
post Dec 7 2017, 12:32 AM
Pretty simple. Drill the holes and rivet it in. Keep an eye on the location of the liner in the arch. It wants to slide up, and you want to keep it tight and tidy against the fender.
Front fender is more of the same.
These were installed without any trimming or tuning of the liner.
Every 914 needs these. 1. Protects the front fender to cowl joint. 2. Protects the seam sealer behind the door latch plate. 3. Keeps debris from getting slung into the jack point. 4. Most important, keeps debris and moisture getting slung up into the poorly designed joint under the sail panel inside the rear fender.
RickS   Who has mounted Mikey’s Fender Liners?   Dec 2 2017, 10:28 PM
cary   The rivets go into the fender liner, not the car. ...   Dec 2 2017, 11:24 PM
RickS   Thanks Cary. That makes total sense. Still have ...   Dec 3 2017, 12:36 AM
cary   Matt and I talked about it one night while putting...   Dec 3 2017, 01:05 AM
Mark Henry   914rubber (and other member vendors) shouldn't...   Dec 3 2017, 08:15 AM
RickS   914rubber (and other member vendors) shouldn...   Dec 4 2017, 01:52 AM
Mark Henry   914rubber (and other member vendors) shouldn...   Dec 4 2017, 07:30 AM
Mikey914   We are actually taking more steps to document inst...   Dec 4 2017, 04:16 AM
cary   Crash Course : The wide one goes it the back. Ste...   Dec 7 2017, 12:13 AM
cary   Pretty simple. Drill the holes and rivet it in. Ke...   Dec 7 2017, 12:32 AM
914forme   Every 914 needs these. 1. Protects the front fe...   Dec 7 2017, 10:22 AM
raynekat   Cary, guess you better sell me those liners. Since...   Dec 7 2017, 12:39 AM
cary   All boxed up and ready to go .................... ...   Dec 7 2017, 12:42 AM
RickS   Thanks Cory for all the valuable info. Is this a ...   Dec 9 2017, 08:50 PM
cary   Thanks Cory for all the valuable info. Is this a...   Dec 9 2017, 11:50 PM
RickS   Here is my misguided attempt to try to make the pi...   Dec 9 2017, 09:03 PM
RickS   Here is the clearance issue with mounting the rear...   Dec 9 2017, 09:20 PM
cary   Here is the clearance issue with mounting the rea...   Dec 10 2017, 12:06 AM
cary   Here's the tab on the left rear. You can see t...   Dec 9 2017, 11:57 PM
RickS   Thank you sir. Got it completely back-asswards. Mu...   Dec 10 2017, 12:37 AM
mlindner   Nice job Cary, and those are some great looking li...   Dec 10 2017, 06:08 AM
Mikey914   Thanks Cary for detailing this out. We will be doi...   Dec 10 2017, 10:45 AM
RickS   Thanks to Cary, got the drivers side done. While t...   Dec 10 2017, 12:28 PM
Jamie   Thanks to Cary, got the drivers side done. While ...   Aug 31 2019, 02:14 PM
SirAndy   Is that grease nipple stock? Nope   Aug 31 2019, 08:45 PM
cary   Hmmmm .... Doug will have the same issue.   Dec 10 2017, 12:38 PM
VaccaRabite   914 rubber needs to make these for a flared BMW 20...   Aug 31 2019, 03:04 PM
rhodyguy   The internet is handy but NOTHING beats paper.   Aug 31 2019, 03:18 PM
Mikey914   Actually changed the mounts to make them a bit eas...   Aug 31 2019, 07:29 PM
- Lo-Fi Version Time is now: 14th March 2026 - 05:02 AM
