| jfort |
Oct 4 2017, 09:18 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,194 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
I doubt that there will be anything earth shattering or even beyond common knowledge, but if only to document this project, here goes:
This is a big, first time project for me, an attorney and mechanic wannabe. My factory six with a 2.5L engine was missing. Turns out there was only 75% compression in #1 and it was leaking through the inlet valve. Auto Assets in Powell OH diagnosed and my friend and mechanic, Jay Kjoller confirmed. Thankfully, Jay, an experienced air cooled engine builder and racer who lives nearby agreed to take on the project and to let me help. I got the engine out and delivered it to Jay last week. ![]() We started the disassembly yesterday. ![]() Learned some things about the engine. It has an early aluminum case with Mahle 90mm pistons and Nikasil cylinders. Pretty sure they are 2.7L. It has a later 3-ribbed oil pump, which Jay says is sufficient for what I do. ![]() The pistons have been lightened, which Jay said was unusual. We expected to see something that would explain the problem with #1. Other than some carbon accumulation on the head where the valve closes there was nothing. But, having gone this far, we decided to go from top end rebuild to a full rebuild and we split the case. Considerations. I think the engine was built into a 2.5 in the early 70's given SCCA classes at the time, but it is just a guess. My prior owner was Jim Chambers in Oregon. He bought the car in 2001 from Werks 2 in in Burbank CA, which was started a long ago by Harry Bieker (Bieker Engineering) and continued by his son, Galen Bieker. I exchanged emails with Galen but he couldn't remember any details that would help us decide how far to go on the rebuild. But Jay said whoever built it did a good job and he can recognize the approximate build date from the materials used, e.g., paper gaskets and 3 thin copper seals at the bottom of the cylinders. What I would call the wear points, (bearings, cam lobes, valve tappets, etc.) looked to be in good shape. But I wanted to be sure. Jays says he has had good experience with something other than the existing E cam, a Solex cam? that is a little more aggressive. So, we are going to either source that or investigate grinding the E cam. ![]() Friday, I will wash all the oily parts. Heads, valves, piston rods go to the machine shop, which is nearby. What can go into a hot bath tank will go there. What can be powder coated will go there. The air shroud, which is green, needs something. Not sure what to do about that. |
| mepstein |
Dec 7 2017, 02:34 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,902 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Unlike a 911, you see mostly see the back of the engine in a 914.
jfort Engine Rebuild Oct 4 2017, 09:18 AM
mepstein Early aluminum case - score! Oct 4 2017, 09:28 AM
Optimusglen Are you running MFI or carbs?
I ask because I... Oct 4 2017, 09:30 AM
jfort The engine has Weber carbs. Let me see what the pl... Oct 4 2017, 09:38 AM
krazykonrad :popcorn:
Looks like an interesting project. Goo... Oct 4 2017, 10:01 AM
Perry Kiehl There's a lot more cam options today, than the... Oct 4 2017, 11:52 AM
Edward Blume Some additional HP sounds like its in your future.... Oct 4 2017, 12:23 PM
GeorgeRud Lot's of folks used the 2.7 CIS pistons and cy... Oct 4 2017, 01:21 PM
davehg Another attorney and wanna-be mechanic also rebuil... Oct 4 2017, 01:37 PM
Rob-O Knew Jay way back in the late 80's. He built ... Oct 4 2017, 04:04 PM
burton73 I am an old friend and customer of Harry Bieker fr... Oct 4 2017, 04:33 PM
mepstein I think today's number is 40 hours but that do... Oct 4 2017, 04:37 PM
Mark Henry
I think today's number is 40 hours but that d... Oct 4 2017, 06:46 PM
Mark Henry I'd consider dumping the pistons, get the cyli... Oct 4 2017, 07:01 PM
gereed75 Highly recommend the mod Solex cam (DC30). Peak po... Oct 4 2017, 10:10 PM
jfort Turns out I was wrong. It is a 70.4 mm crank with ... Oct 5 2017, 06:37 PM
Mark Henry
Turns out I was wrong. It is a 70.4 mm crank with... Oct 6 2017, 09:49 AM
Dr Evil Hey neighbor! Cool build. I didn't know pe... Oct 6 2017, 09:28 AM
jfort Jay recommends staying with the German Mahle pisto... Oct 7 2017, 05:45 PM
Cairo94507 Excellent project. :popcorn: Oct 7 2017, 09:17 PM
jfort update on the build
got the engine tin and the en... Dec 6 2017, 12:44 PM
Mark Henry On the twin plug carbs with a trigger ignition her... Dec 6 2017, 01:53 PM
jfort thanks, Mark! Dec 6 2017, 02:51 PM
jd74914 I believe you can also use Microsquirt now for 6 c... Dec 6 2017, 04:13 PM
Mark Henry
I believe you can also use Microsquirt now for 6 ... Dec 6 2017, 08:43 PM
jd74914
Yeh who wants to put that super old 90's EDIS... Dec 7 2017, 03:40 AM
Larmo63 I have a 2.4 7R cased motor with Daugherty cams DC... Dec 6 2017, 04:52 PM
Justinp71 :popcorn:
My uncle has a 2.5L in his '70 911,... Dec 6 2017, 06:29 PM
gereed75 Assuming mean the hole for twin plugs, I bet Craig... Dec 6 2017, 06:46 PM
914forme I have the SDS system here, and the extra coil pac... Dec 6 2017, 07:41 PM
Mark Henry Since the OP is running carbs the MS box is anothe... Dec 7 2017, 06:09 AM
Since the OP is running carbs the MS box is anoth... Dec 7 2017, 06:25 AM
JmuRiz Another in agreement with the two above....I'm... Dec 7 2017, 09:27 AM
brant I agree with the above.
no need to go to twin plug... Dec 7 2017, 09:38 AM
914Toy Like Larmo, I have just installed single plug Clew... Dec 7 2017, 09:53 AM
Mark Henry Nice :wub:
But I'll raise you by 3.0 :evil... Dec 7 2017, 10:01 AM
jfort beautiful! now we're talking. almost too b... Dec 7 2017, 11:01 AM
Mark Henry Brant and I are running TP dizzy's, Brant (lik... Dec 7 2017, 11:35 AM
pete-stevers I won't be running twin plugs in any engine bu... Dec 7 2017, 09:55 PM
jfort Making progress. Took the heads up to Craig Barret... Jan 19 2018, 02:39 PM
sixnotfour Is that a small oil pump ?? 3 rib or sandcast ? a... Jan 19 2018, 03:14 PM
jfort 3-ribbed later oil pump Jan 19 2018, 03:51 PM
914forme :poke: 1966 :poke: did I read that right :blink: ... Jan 19 2018, 06:15 PM
davesprinkle Love this thread. But can we please rotate the im... Jan 19 2018, 08:26 PM
burton73 You need some 1966 chain cases from the 69s Eng. f... Jan 19 2018, 11:08 PM
jfort I don’t understand the question Jan 20 2018, 05:36 PM
jfort Spent the second day on the rebuild yesterday. Rec... Jan 27 2018, 11:32 AM
mb911
Spent the second day on the rebuild yesterday. Re... Jan 28 2018, 07:54 AM
jfort We next had to determine the swept volume and the ... Jan 27 2018, 11:54 AM
jfort A post script. Getting to know Jay Kjoller is a jo... Jan 27 2018, 12:01 PM
gereed75 What exactly are you measuring using the solder me... Jan 28 2018, 09:12 AM
mb911
What exactly are you measuring using the solder m... Jan 28 2018, 09:27 AM
jfort Did volume of combustion chamber measurement with ... Feb 25 2018, 07:54 AM
jfort Had to add - I am continually impressed by engine ... Feb 25 2018, 08:05 AM
mepstein I just sold a rebuilt engine with an early sand ca... Feb 25 2018, 08:08 AM
jfort Jugs are back from Wisconsin with new nikisol. (Si... Apr 8 2018, 03:56 PM
jfort almost too pretty to put back in
Apr 11 2018, 03:16 PM
flyer86d That should be one snotty engine!
Charlie Apr 11 2018, 04:48 PM
jfort rebuilt carbs May 15 2018, 11:40 AM
jfort JE Pistons ready. 10.8:1. had to re-shape bevel to... May 15 2018, 11:43 AM
jfort re-nikasiled jugs to achieve correct tolerance May 15 2018, 11:46 AM
jfort pistons going in and jugs on May 15 2018, 11:48 AM
jfort RE: Engine Rebuild May 15 2018, 11:49 AM
jfort RE: Engine Rebuild May 15 2018, 11:50 AM
jfort heads on May 15 2018, 11:51 AM
jfort cam housing going on. Loctite 574 doing the sealin... May 15 2018, 11:53 AM
jfort RE: Engine Rebuild May 15 2018, 11:54 AM
jfort measure depth of and aligning chain sprockets. new... May 15 2018, 11:56 AM
jfort the intermediate shaft has a specified "play... May 15 2018, 12:00 PM
jfort timing the cams took a lot of time. based on Dough... May 15 2018, 12:02 PM
jfort PERFECT!!
May 15 2018, 12:03 PM
jfort lubed cam lobes, added chain tensioners and covers... May 15 2018, 12:08 PM
jkb944t
lubed cam lobes, added chain tensioners and cover... May 16 2018, 05:46 AM
jfort measuring and adjusting accelerator pump injection... May 17 2018, 08:32 AM
jfort getting close
May 17 2018, 08:34 AM
jfort mating with the car starts Saturday
May 17 2018, 08:36 AM
sb914 Mating is the best part :wub: looks fantastic... May 17 2018, 08:45 AM
jfort Anyone have any guidance as to where to mount the ... May 17 2018, 06:18 PM
wndsrfr
Anyone have any guidance as to where to mount the... May 18 2018, 05:59 AM
Larmo63 I mounted them in the trunk......Clewett system
May 18 2018, 08:28 AM
jfort ended up fabricating a mount for the direct igniti... May 31 2018, 10:50 AM
jfort RE: Engine Rebuild May 31 2018, 10:51 AM
jfort RE: Engine Rebuild May 31 2018, 10:52 AM
jfort had to get the custom length wires through the tin... May 31 2018, 10:53 AM
jfort RE: Engine Rebuild May 31 2018, 10:54 AM
jfort note heat shrink on wire connections and the wire/... May 31 2018, 10:55 AM
jfort then we checked the axles as they had come apart w... May 31 2018, 10:58 AM
jfort lubed up
May 31 2018, 10:59 AM
Mark Henry Looking good :thumbsup: May 31 2018, 12:50 PM
jfort went in yesterday. took time to re-route oil lines... Jun 12 2018, 09:25 AM
jfort Engine installed last week. Thought we were ready ... Jul 2 2018, 12:14 PM
jfort wrapping this up. I replaced Webers with PMO. l c... Sep 7 2018, 02:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th September 2026 - 04:23 AM |
