Pedal Board Install, Do you leave your gas pedal attached? hints |
Calwaterbear |
Dec 9 2017, 05:44 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
I'm assuming the pedal board can be installed over the pedal set without unbolting the gas pedal from the floor. So that would mean I'm an idiot. So any hints?
iankarr |
Dec 9 2017, 08:19 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,480 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Yeah removing the pedal board is a little like one of those bar puzzles. It’s a little easier if you remove the rubber off the pedals but basically you tilt the top part of the board towards you and maneuver the clutch pedal out first then the brake pedal easily follows. Def no need to unbolt the accelerator pedal.
Matt...great tip about reinstalling the ball connector! |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:39 AM |
