| RickS |
Dec 2 2017, 10:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Just received the box with the liners. Instead of the stated “clips” for mounting they came with rivets. Clips suggest clipping the liners to the fenders or other attachment points rivets on the other hand... Am a bit hesitant to start drilling holes in my original sheet metal. No instructions were provided either.
Any one done this or have suggestions of the least invasive way they mounted these not using “clips”? |
| RickS |
Dec 9 2017, 09:20 PM
Here is the clearance issue with mounting the rear There just doesn’t seem to be room to fit the liner with the bracket since it hits the suspension. Also how do you get to the zirk with the liner in place?
if the solution is to mount the L bracket on the inside, how do you access the bolt to remove the rocker without drilling out the rivers? I am repainting the rockers and was going to put them on last. |
RickS Who has mounted Mikey’s Fender Liners? Dec 2 2017, 10:28 PM
cary The rivets go into the fender liner, not the car. ... Dec 2 2017, 11:24 PM
RickS Thanks Cary. That makes total sense. Still have ... Dec 3 2017, 12:36 AM
cary Matt and I talked about it one night while putting... Dec 3 2017, 01:05 AM
Mark Henry 914rubber (and other member vendors) shouldn't... Dec 3 2017, 08:15 AM
RickS
914rubber (and other member vendors) shouldn... Dec 4 2017, 01:52 AM
Mark Henry
914rubber (and other member vendors) shouldn... Dec 4 2017, 07:30 AM
Mikey914 We are actually taking more steps to document inst... Dec 4 2017, 04:16 AM
cary Crash Course : The wide one goes it the back.
Ste... Dec 7 2017, 12:13 AM
cary Pretty simple. Drill the holes and rivet it in. Ke... Dec 7 2017, 12:32 AM
914forme
Every 914 needs these. 1. Protects the front fe... Dec 7 2017, 10:22 AM
raynekat Cary, guess you better sell me those liners.
Since... Dec 7 2017, 12:39 AM
cary All boxed up and ready to go .................... ... Dec 7 2017, 12:42 AM
RickS Thanks Cory for all the valuable info. Is this a ... Dec 9 2017, 08:50 PM
cary
Thanks Cory for all the valuable info. Is this a... Dec 9 2017, 11:50 PM
RickS Here is my misguided attempt to try to make the pi... Dec 9 2017, 09:03 PM
cary
Here is the clearance issue with mounting the rea... Dec 10 2017, 12:06 AM
cary Here's the tab on the left rear. You can see t... Dec 9 2017, 11:57 PM
RickS Thank you sir. Got it completely back-asswards. Mu... Dec 10 2017, 12:37 AM
mlindner Nice job Cary, and those are some great looking li... Dec 10 2017, 06:08 AM
Mikey914 Thanks Cary for detailing this out. We will be doi... Dec 10 2017, 10:45 AM
RickS Thanks to Cary, got the drivers side done. While t... Dec 10 2017, 12:28 PM
Jamie
Thanks to Cary, got the drivers side done. While ... Aug 31 2019, 02:14 PM
SirAndy Is that grease nipple stock?
Nope Aug 31 2019, 08:45 PM
cary Hmmmm ....
Doug will have the same issue. Dec 10 2017, 12:38 PM
VaccaRabite 914 rubber needs to make these for a flared BMW 20... Aug 31 2019, 03:04 PM
rhodyguy The internet is handy but NOTHING beats paper. Aug 31 2019, 03:18 PM
Mikey914 Actually changed the mounts to make them a bit eas... Aug 31 2019, 07:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 05:03 AM |
