911 suspension compatibility question |
jt914 |
Dec 9 2017, 12:09 PM
I love my914 Group: Members Posts: 26 Joined: 20-March 14 From: Pinon Hills, CA Member No.: 17,141 Region Association: Southern California |
jpnovak |
Dec 10 2017, 02:29 PM
They call me "Nanoman" Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region |
Those are 74-89 underbody sway bars. These will only work if you have the aluminum cross-member, rear tie-connectors and underbody specific sway bar bushing brackets that mount to the rear tie connectors.
You need the full system to run that sway bar. The a-arms by themselves will work. If you want to run a through-body sway bar, cut off the sway bar mounts and have the new drop link mount welded (better) or bolted in place. |
Chris914n6 |
Dec 10 2017, 10:16 PM
Jackstands are my life. Group: Members Posts: 3,338 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Those are 74-89 underbody sway bars. These will only work if you have the aluminum cross-member, rear tie-connectors and underbody specific sway bar bushing brackets that mount to the rear tie connectors. You need the full system to run that sway bar. I beg to differ. I just drilled and threaded a hole for the mounting bracket into the steel crossmember. I kept the steel tube crossmember because if fit better with the rad hoses, otherwise stock 911 susp. |
Lo-Fi Version | Time is now: 11th June 2024 - 01:16 AM |
