jt914 |
I love my914 ![]() Group: Members Posts: 26 Joined: 20-March 14 From: Pinon Hills, CA Member No.: 17,141 Region Association: Southern California ![]() |
Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks
jason Here is some of it: Front Brake calipers $40 Brake Pistons $5each Brake Hardware $1 and up Master Cylinders $25 Proportioning Valve $25 Hard Brake Lines $5ea Brake Dust Shields$5ea Rear Valance$100 Rear Bumper Core$50 Dog Bones$1ea Fiberglass Rocker panel pair$50 Hella Tail Light Lens pair$100 Hella Side Marker assembly and lens$25ea Tail Light Plastic Nuts$FREE Headlights$10 Headlight Motors$20 Turn Signal Buckets$20 Fuel Injection ECU $50 FI Harnesses$50 1.7 205F Distributors$50 Trigger Points$50 Relay Boards, Covers, Hold-Down Bolts$5-20 Relays $3ea Fuel Pressure Regulators$30 Deceleration Valves$20 Fuel Rails$2ea Voltage Regulators$10ea 1.7 Djet Injection Parts from 1973 Fuel Pressure Sender Connectors and harness parts Coils$10ea 2.0 Manifold$25 Distributor Drive Gears$25 Rear Trunk Lock$25 Rear Trunk Latch and Plunger$25 Inner Door Lock Mechanism $20 Striker Plates$10pr New Front Trunk Weatherstrip Seal $40 Engine Lid Welting Front Targa Latches $25 Window Roller Assembly $25 Front Cowl Seals $5 Dash Skeleton$50 Steering Column$25 Heater Parts Dash Fresh Air Controls$25 Glove Boxes, Doors$10ea Glove box Lock$15 Window Crank Handles$3 Vents$10 Triangle side window glass$10 Rear window$25 Coat Hooks$10 Front Trunk Release Handle and Lock$15 Pedal Clusters$50 Pedal Cluster Parts Pedal Boards$10 1.7 shortblock has not been split open w crank, cam, rods$200 Cranks 1.7 $50 Connecting Rods 1.7 $50set Rocker Arm Assembly 2.0 $100 Oil Coolers$10 Pushrods and Tubes$2 1.7 Heat Exchangers blasted and painted$100 1.7 Heads $100 2.0 Head 75-76 needs repair $40 Valve Covers and Bales $30 Driver seat$60 Seat Tracks$25ea Center pad and plastic tray $15 Fuel Combo Gauge Silver Dot$30 Gauge Bezels Metal $20 or Plastic$10 914 A-arms$80 Front Struts and Spindles$50 . And so I don't break any more rules, I wish to be paid in cash. Or paypal if parts need shipped. plus actual shipping and packaging if needed. |
Ed_Turbo |
Member ![]() ![]() Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California ![]() |
I am looking for these:
- H-frame for license plate - Glove box door - Lugs For late model 914-4. |
jt914 |
Ed_Turbo |
I am looking for these: - H-frame for license plate - Glove box door - Lugs For late model 914-4. Hi Ed, I'm out of town til Saturday but can definitely get you set up with all of those parts. Do you need long or short lugs? For short lugs? Stock lugs for stock wheels. |
Lo-Fi Version | Time is now: 17th June 2024 - 03:13 AM |
