Fuel pump polarity (&other questions) |
jmitro |
Dec 22 2017, 07:10 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I’ve searched for 3 hours and cannot find the polarity of this Bosch in-line fuel pump. The terminals are not labeled positive or negative, only a smaller M4 terminal and larger M5. Which one is positive and which is negative?
For chassis wiring - the (EDIT) brown is ground and black/red is positive, correct? finally, if I locate the pump to the trunk, how do I back track the wiring from the engine compartment to the trunk? it still needs to go through the relay which is in the engine bay Attached thumbnail(s) |
JeffBowlsby |
Dec 22 2017, 07:47 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I dunno. But if the case is grounded there may be continuity between one of the terminals and the case. Maybe?
Lo-Fi Version | Time is now: 8th June 2024 - 08:18 AM |
