Fuel pump polarity (&other questions) |
jmitro |
Dec 22 2017, 07:10 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I’ve searched for 3 hours and cannot find the polarity of this Bosch in-line fuel pump. The terminals are not labeled positive or negative, only a smaller M4 terminal and larger M5. Which one is positive and which is negative?
For chassis wiring - the (EDIT) brown is ground and black/red is positive, correct? finally, if I locate the pump to the trunk, how do I back track the wiring from the engine compartment to the trunk? it still needs to go through the relay which is in the engine bay Attached thumbnail(s) |
914Sixer |
Dec 22 2017, 10:10 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I will look at a pump I have tomorrow. I am thinking the larger is ground and smaller is positive.
Lo-Fi Version | Time is now: 8th June 2024 - 05:06 PM |
