Fuel pump polarity (&other questions) |
jmitro |
Dec 22 2017, 07:10 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I’ve searched for 3 hours and cannot find the polarity of this Bosch in-line fuel pump. The terminals are not labeled positive or negative, only a smaller M4 terminal and larger M5. Which one is positive and which is negative?
For chassis wiring - the (EDIT) brown is ground and black/red is positive, correct? finally, if I locate the pump to the trunk, how do I back track the wiring from the engine compartment to the trunk? it still needs to go through the relay which is in the engine bay Attached thumbnail(s) |
jmitro |
Dec 23 2017, 05:29 AM
that's what I thought also, but in searching other forums I saw the opposite.
The instructions with this pump had nothing about polarity and do not even show the direction of fuel flow. (IMG:style_emoticons/default/headbang.gif) I finally figured out the outlet was the smaller port next to the terminals |
Lo-Fi Version | Time is now: 8th June 2024 - 06:37 PM |
