Fuel pump polarity (&other questions) |
jmitro |
Dec 22 2017, 07:10 PM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
I’ve searched for 3 hours and cannot find the polarity of this Bosch in-line fuel pump. The terminals are not labeled positive or negative, only a smaller M4 terminal and larger M5. Which one is positive and which is negative?
For chassis wiring - the (EDIT) brown is ground and black/red is positive, correct? finally, if I locate the pump to the trunk, how do I back track the wiring from the engine compartment to the trunk? it still needs to go through the relay which is in the engine bay Attached thumbnail(s) |
Front yard mechanic |
Dec 23 2017, 08:36 AM
Senior Member Group: Members Posts: 1,172 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Simple hook up power and test pump it with water I've done this many times and the water doesn't ruin the pump. Then run it dry for a few to drain the water
Lo-Fi Version | Time is now: 8th June 2024 - 08:53 PM |
