Subaru Transmission Block Off Plates and Hydraulic Clutch Mount, Block-Offs $45, Hydraulic Clutch mounts $65 I have 10 of each! |
rnellums |
Dec 15 2016, 07:37 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I'm going to put another order in for some block off plates for the Subaru transmission conversions. It's a simple 1/8" laser cut aluminum plate with the holes in the right places. I will be putting in the order Monday, to take payment once they ship.
Attached image(s) |
Amenson |
Dec 28 2017, 01:27 PM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
I just tried mocking this up using several different Tilton and Wilwood master cylinders I have and the bolt spacing and center hole size id different.
Which master cylinder is intended to be used with this plate? |
rnellums |
Dec 28 2017, 06:55 PM
I just tried mocking this up using several different Tilton and Wilwood master cylinders I have and the bolt spacing and center hole size id different. Which master cylinder is intended to be used with this plate? Its a Honda MC 5/8", 1993-2000 civic. Original pioneering work done by Kent and Chris Here starting at post #499 http://www.914world.com/bbs2/index.php?sho...1776&st=480 The process if pretty well illustrated in Ray's thread here, starting around post #111 http://www.914world.com/bbs2/index.php?sho...20569&st=90 Pictures of my install here, Starting at post 15: http://www.914world.com/bbs2/index.php?sho...300932&st=0 I drilled a small hole for the front of the master cylinder to pass through (and sealed it with a rubber grommet from Ace). Seems like I may need to do a more fully illustrated write up. Maybe next week once I get home I can put the car up and do more of a walk through. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:53 AM |
