Pushrod Tube Retainer, Pushrod Tubes leaking at the seals |
RenoRoger |
Jan 4 2018, 02:11 AM
Member Group: Members Posts: 95 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California |
Changed pushrod tube seals to fix a slight leak. In the process, I must have bent the rod retainer, Part # 021109339, slightly which caused a bigger leak. While trying to bend that hoaky springlike contraption, it broke. Has anyone designed a better one that puts more pressure on the tubes and seals? The original design seems not very effective. So far I have not been able to find a replacement.
cwpeden |
Jan 4 2018, 08:26 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
The spring doesn't actually aid in sealing. Its just a retainer, which is necessary.
If the leak wasn't fixed then I suggest that you may have left some soil in there. |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:05 AM |
