> My '70 V-8 Assembly Thread, a few updates and pic's
76-914
post Oct 14 2017, 02:44 PM
If you didn't see elsewhere this is a 1970 914 w/ a 327 and 901 transmission. I purchased the car from "Bullit" and here is some info I gotten thus far. The wiring harness is out of a '73; the front end is off a 911 but I forget which year w/ "M" calipers; Trailing arms have some of Foley's reinforcement kit; Engman inner stiffener kit was installed; Griffen radiator;window regulators from a '73; stock 914 1/2 shafts and a lot more which I'll note later.
I'm presently working on the rear brakes and trailing arms and have 2 questions. What is the torque valve for the nut that my torque wrench is attached to; 108 ft lb or 50 ft lb?
The manual says 50 for "Control arm bearing/body" and 108 ft lbs for the "Control arm bearing/control arm". Not sure which is which! (IMG:style_emoticons/default/confused24.gif)
Attached ImageAttached Image
post Jan 4 2018, 11:32 AM
I don't know how people get anything done on their conversion if they don't work on them daily. I didn't touch mine for two weeks because of the Holidays & and related travels. I went out to the garage last nite and just stared at it. Couldn't get the motion going whereas if I work on it a little every day I can immediately pick up where I left off. Be it a 20 min session or an 8 hour session.
Since I have the brakes working and an exhaust system in place it's time to address the 1st gear issue with the transmission. Bob said it was rebuilt at one of Dr Evil's clinics but he skipped installing a new synchro on 1st. Hope I don't discover it's the more expensive 1st gear slider. However, I've decided to surprise my son in Tx with this car and want him to have a fully functional transmission. I'd thought about giving him the Subaru conversion but if he had a mechanic that wasn't willing to spend extra time figuring out how the old and new electronics were married then the car might sit and rot should he encounter any problems. This car with the old school carb, mechanical fuel pump, etc can be serviced by most mechanics. Besides, he is young enough to enjoy this type car. Flashy and loud. A steroid emitting Hot Rod! (IMG:style_emoticons/default/av-943.gif)
So, next up is the transmission repair and installing an interior. I'll post a few pics next time.
Hope all of you guys had a great Christmas and New Years. (IMG:style_emoticons/default/beerchug.gif)
Chris914n6
post Jan 4 2018, 09:36 PM
Jackstands are my life.
QUOTE(76-914 @ Jan 4 2018, 09:32 AM) *
It's nice to hear I'm not the only one with that problem. (IMG:style_emoticons/default/beerchug.gif) And being a 914 I have to block off 1-2 hours minimum to get anything done.
I rarely start off in 1st with my V6, won't need it at all with a V8. So not really a problem if it isn't up to snuff. Go drive it.
76-914   My '70 V-8 Assembly Thread   Oct 14 2017, 02:44 PM
Chris914n6   108. 50 is for the 3 bolts on the "adjustment...   Oct 14 2017, 02:53 PM
76-914   108. 50 is for the 3 bolts on the "adjustmen...   Oct 14 2017, 03:15 PM
76-914   2nd question. The new E brake cable head came with...   Oct 14 2017, 03:13 PM
zig-n-zag   I say 108 ftlbs for the nut, and the three bolts w...   Oct 14 2017, 04:10 PM
76-914   Must be 108 if both you guys agree. I couldn't...   Oct 14 2017, 05:30 PM
burton73   That spot will be covered by a Ducktail spoiler so...   Oct 14 2017, 09:03 PM
76-914   That spot will be covered by a Ducktail spoiler s...   Oct 15 2017, 09:42 AM
barefoot   . While I was at it I did the same on the left sid...   Oct 19 2017, 05:43 AM
76-914   I spent this morning doing a little house cleaning...   Oct 15 2017, 02:40 PM
KELTY360   Also took a good pic of the block casting # ...   Nov 3 2017, 07:48 PM
Andyrew   I found this on the head casting, looks like maybe...   Oct 15 2017, 06:52 PM
bulitt   Andrew thats the info I have Heads- 3998993 rebuil...   Oct 15 2017, 07:46 PM
rhodyguy   Be pointed forward when you go for the first big t...   Oct 16 2017, 07:14 AM
76-914   Be pointed forward when you go for the first big ...   Oct 16 2017, 06:47 PM
ValcoOscar   [quote name='rhodyguy' post='2538119' date='Oct 1...   Oct 16 2017, 07:53 PM
Larmo63   "Mr. Ugly" was staring back at you? ...   Oct 16 2017, 08:02 PM
76-914   I tried to install these today but their appx 1...   Oct 18 2017, 08:17 PM
Chris914n6   I tried to install these today but their appx 1...   Oct 18 2017, 11:29 PM
Mike Bellis   327 is a great SBC choice in a 914. Good power, no...   Oct 18 2017, 08:58 PM
Cracker   Welcome to the World of fun 914's Kent...nothi...   Oct 19 2017, 04:26 AM
76-914   327 is a great SBC choice in a 914. Good power, n...   Oct 19 2017, 07:53 AM
Andyrew   I had 225's on mine as well, even had 275...   Oct 19 2017, 09:23 AM
whitetwinturbo   :popcorn: ..and who makes that "better" ...   Oct 21 2017, 08:22 AM
76-914   :popcorn: ..and who makes that "better...   Oct 21 2017, 09:02 AM
76-914   I'm working on "how to" use the exis...   Oct 22 2017, 05:15 PM
76-914   Finally got a chance to work on Red today. Finishe...   Oct 28 2017, 09:40 PM
76-914   Made the rough cut templates out of cardboard. The...   Nov 2 2017, 08:23 PM
76-914   The side will get a trim flange to fill the void o...   Nov 2 2017, 08:27 PM
Andyrew   Looks good!!!   Nov 2 2017, 08:40 PM
bulitt   :trophy:   Nov 3 2017, 05:15 AM
rhodyguy   Kent, contact TC914-8 (tony) about the carb linkag...   Nov 3 2017, 09:11 AM
76-914   Thx Andrew and Bob. When I peel back that protecti...   Nov 3 2017, 05:33 PM
76-914   Good eye Mark. I totally missed that. Now where wa...   Nov 8 2017, 10:10 PM
Blue6   :cheer:   Nov 8 2017, 10:43 PM
Larmo63   Damn, Kent. That looks pretty good. I have to get ...   Nov 8 2017, 11:19 PM
rhodyguy   Fast work Kent! Carry on.   Nov 9 2017, 07:51 AM
76-914   Got'a keep moving if I want to sell this thing...   Nov 9 2017, 08:50 AM
Andyrew   A chemical might help remove it. There might be so...   Nov 9 2017, 09:33 AM
bulitt   It was a temp install to transport the car 2500 mi...   Nov 9 2017, 03:59 PM
Chris914n6   I usually just use a wire brush by hand and my thu...   Nov 9 2017, 03:59 PM
76-914   Yeah Chris, When I get after it I will remove that...   Nov 9 2017, 08:09 PM
914forme   3M adhesive earser wheel   Nov 9 2017, 08:39 PM
76-914   That's it Stephan. But it's about 3/16...   Nov 9 2017, 10:16 PM
bulitt   Wire wheel for a dremel?   Nov 10 2017, 06:10 AM
76-914   Wire wheel for a dremel? Yea Bob, I'm thinki...   Nov 10 2017, 08:41 AM
914_teener   Wire wheel for a dremel? Yea Bob, I'm think...   Nov 10 2017, 08:45 AM
76-914   Delete that Rob. I don't want her to see that....   Nov 25 2017, 06:05 PM
76-914   Since I have this huge mass of cast iron I added a...   Nov 25 2017, 06:41 PM
bulitt   Isn't this car running yet? :D Great Job Ke...   Nov 26 2017, 09:18 AM
76-914   It is now but there is still a lot to do. :beer2:...   Dec 11 2017, 06:27 PM
ValcoOscar   It is now but there is still a lot to do. :beer2...   Dec 11 2017, 08:08 PM
bulitt   Woo Hoo! Can't tell if you hooked up the ...   Dec 11 2017, 08:42 PM
Cracker   Way to go Kent!!! :beer2: :trophy:...   Dec 11 2017, 08:50 PM
bulitt   Way to go Kent!!! :beer2: :trophy...   Dec 11 2017, 08:53 PM
Cracker   I remember that now...long time ago! Cool. To...   Dec 11 2017, 08:59 PM
Andyrew   Mmmm Torque, glorious torque!!! Congra...   Dec 12 2017, 07:08 AM
sb914   Nice job ! :Qarl:   Dec 12 2017, 07:17 AM
bulitt   7hCf3HRTc84   Dec 12 2017, 07:43 AM
rhodyguy   Do you need another horn pad?   Dec 12 2017, 08:15 AM
Larmo63   Sounds great so far....!!!!!...   Dec 12 2017, 07:36 PM
76-914   Thanks guys. The growl raised my testosterone leve...   Dec 12 2017, 09:19 PM
burton73   Thanks guys. The growl raised my testosterone lev...   Dec 13 2017, 12:44 PM
76-914   Thanks guys. The growl raised my testosterone le...   Dec 13 2017, 06:34 PM
914350   I love the way you mounted the radiator. The shrou...   Dec 13 2017, 11:18 AM
76-914   I love the way you mounted the radiator. The shro...   Dec 13 2017, 06:31 PM
Cracker   I believe it is way too early to determine value.....   Dec 13 2017, 07:13 PM
burton73   I believe it is way too early to determine value....   Dec 13 2017, 07:58 PM
Cracker   Ok. With that logic...why stop at 4x? Kent - go fo...   Dec 13 2017, 08:03 PM
76-914   Who knows? I certainly don't. The interior sho...   Dec 14 2017, 09:13 AM
Andyrew   A sorted v8 car in good condition is between 10-15...   Dec 14 2017, 09:27 AM
Cracker   Anyone wanting a radio in that car should not be a...   Dec 14 2017, 09:41 AM
burton73   Anyone wanting a radio in that car should not be ...   Dec 14 2017, 10:32 PM
Chris914n6   Anyone wanting a radio in that car should not be ...   Dec 16 2017, 03:35 PM
Mueller   Anyone wanting a radio in that car should not be ...   Jan 4 2018, 11:51 AM
rhodyguy   :agree: don't fret about a radio.   Dec 14 2017, 10:07 AM
76-914   So I'm killing time waiting on the mufflers to...   Dec 14 2017, 07:16 PM
76-914   I've decided to complete this 914 w/o a radio....   Dec 16 2017, 07:40 PM
Chris914n6   I've decided to complete this 914 w/o a radio...   Dec 16 2017, 08:57 PM
76-914   Thx Chris. I've since discovered that 914rubbe...   Dec 19 2017, 09:22 PM
76-914   I don't know how people get anything done on t...   Jan 4 2018, 11:32 AM
Cracker   Great idea Kent - great Dad!!! I hope ...   Jan 4 2018, 11:54 AM
76-914   Great idea Kent - great Dad!!! I hope...   Jan 4 2018, 09:00 PM
bulitt   I don't know how people get anything done on ...   Jan 4 2018, 07:34 PM
Chris914n6   I don't know how people get anything done on ...   Jan 4 2018, 09:36 PM
rhodyguy   Nice. Don't forget to add transport to the p...   Jan 4 2018, 12:16 PM
914forme   :headbanger:   Jan 4 2018, 09:34 PM
76-914   :headbanger: Oh yea, I forgot your in that tribe...   Jan 5 2018, 11:34 PM
get off my lawn   About a million years ago I was at Irwindale racew...   Jan 8 2018, 06:29 PM
76-914   About a million years ago I was at Irwindale race...   Jan 13 2018, 10:20 PM
bulitt   Wow! Great job!   Jan 14 2018, 06:09 AM
76-914   Thx Bob.Wow, I just realized I forgot to mention t...   Jan 14 2018, 10:44 AM
Cracker   Good for you Kent... When the "hand-off...   Jan 14 2018, 11:01 AM
76-914   Good for you Kent... When the "hand-off...   Jan 14 2018, 11:19 AM
76-914   I forgot to add these pic's once I closed up t...   Jan 14 2018, 01:39 PM
mepstein   Very clean looking. Is that an RH setup?   Jan 14 2018, 01:49 PM
Mueller   Nice radiator setup...might want to add a bead or ...   Jan 14 2018, 02:31 PM
dakotaewing   Try some Denatured alcohol to the cover to remove ...   Jan 14 2018, 05:42 PM
rhodyguy   Nice work Kent.   Jan 14 2018, 06:00 PM
76-914   Very clean looking. Is that an RH setup? Don...   Jan 15 2018, 09:19 AM
- Lo-Fi Version Time is now: 5th September 2025 - 05:09 AM
