> E Z wireing?, anyone every try EZ wire harness for 914
Calwaterbear
post Jan 6 2018, 09:49 PM
getting to the point where i will be starting on Electrical, and I am scared to death of the German wiring - not much good at electronics anyway, and looking at 45 years of degradation.
My buddy has used EZ Wire Kits
http://www.ezwiring.com/store/
in several of his projects, essentially pull out all the wires, put in the EZ wire system. 18 fuses, 21 circuits, all the wires are color coded and labelled every 5 inches, you just take the appropriate wire to the correct location, and attach it. That sounds a whole lot more appealing that trying to figure out german wire diagrams, and chase down what is almost assuredly multiple shorts and ground issues.
Not interested in Historical accuracy - restoring a junk yard find to fun driver, canyon carver! so reliability counts alot!
post Jan 6 2018, 10:20 PM
IMHO, anything that says easy, usually ain't. What's got you scared about the OEM wiring? There are plenty of schematics w/ no guess work. Just a quick look at that harness I'd say the cigarette lighter etc would be a snap but when you begin to disect the blinker system, retract headlights, etc. your going to wish you had stayed OEM. You might need to add a few new spade ends or cut out a bad section of the OEM harness but at least all the guess work is already done and it's just a matter of taking the wire from point A to point B. I've messed with a couple of 914's now. Stock and conversions and IMHO you'd be better off dressing up that 40 yo harness that was made for your car. Another thing; if you run up against a problem with the OEM system there are several here that can assist you. If you go custom your on your own. (IMG:style_emoticons/default/beerchug.gif)
Calwaterbear   E Z wireing?   Jan 6 2018, 09:49 PM
76-914   IMHO, anything that says easy, usually ain't. ...   Jan 6 2018, 10:20 PM
aharder   IMHO, anything that says easy, usually ain't....   Jan 6 2018, 10:58 PM
shoguneagle   Totally, totally agree! Been there, done that...   Jan 7 2018, 12:07 AM
Larmo63   I too agree with Kent. Unless you have a total mes...   Jan 7 2018, 12:23 AM
Rand   Bowlsby is our local wiring guru and makes nice ha...   Jan 7 2018, 12:27 AM
Jett   Bowlsby is our local wiring guru and makes nice h...   Jan 7 2018, 11:22 AM
Mike Bellis   EZ wiring is setup for American cars. The turn sig...   Jan 7 2018, 12:56 AM
Mueller   I'm using something similar for my '78 Vol...   Jan 7 2018, 04:19 PM
gothspeed   I too agree with Kent. Unless you have a total me...   Jan 8 2018, 02:57 PM
wysri9   OK guys - its time for the big reveal! Like m...   Jan 9 2018, 03:50 AM
Mueller   OK guys - its time for the big reveal! Like ...   Jan 9 2018, 08:56 AM
Mueller   This is the system I'd run if I had the funds:...   Jan 9 2018, 08:51 AM
rick 918-S   Wysri9 :screwy: But :beer2: I used Hot Rods Wir...   Jan 9 2018, 01:26 PM
matthepcat   You might want to talk to member "fasthonda...   Jan 9 2018, 03:11 PM
Jeff Bowlsby   Its an insane proposition to try this once you thi...   Jan 9 2018, 03:44 PM
gothspeed   Its an insane proposition to try this once you th...   Jan 9 2018, 07:12 PM
Mike Bellis   Looks like you have skills. I grafted a 2000 Passa...   Jan 9 2018, 10:20 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:14 PM
