HELP!! Need rocker shaft!!, So That's why it won't run!!!!! |
crash914 |
Nov 6 2004, 04:10 PM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Found out why my motor won't run correctly, spitting out the intake....
valves were tight on this cylinder... took off the rocker shaft to replace an O-ring...rockers won't move on the shaft???? Turns out the rockers are galled to the shaft!!!! (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/sad.gif) So for sure this was holding the intake valve open.... anyone have a set of rocker shafts? at a minimum I need 1 shaft and 2 rockers...I am running swivel feet so need a 1.7? rocker??? If anyone has a complete set of 8 I will take them all...please contact me ASAP so I can get this monster running.... PM or email to hberwald@stonyfield.com...if you want, you can call to 603.370.1467. thanks! |
Jake Raby |
Nov 8 2004, 03:43 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
All that grinding material is death for the engine- death.
I cannot stress enough how every part has to be clean and dry with no debris. I wipe all parts down with alcohol or Ether as I assemble and blow them down with air on top of that. Change that oil as soon as possible! Crank it, drive it around the block and then change the oil and filter. |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:44 PM |
