GB from 914Rubber water hoses like factory ! (3 of 200), Full set $20 all you need to replace the system |
Mikey914 |
Jan 13 2018, 04:15 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So thanks to a customer doing a high end restoration we made the rubber hoses like factory used. Others are offering a clear hose that is well... just not period correct.
The hose kit consists of the tire to male end connector (hose shown). The short hose to the cap The tank hose to stalk Stalk to T fitting hose 2 (one long one short) t fitting to squirter hoses I have them bagged in sections to help make it easier. One thing we did diferently was make the hose slightly thicker to give it more grip on the fittings. So you will not need to band them like factory did to get them to stay. They are a VERY tight fit and will require some soappy water to install on the fittings. These are not cheap silicone hoses, and have the correct gloss level. We did a limited run on these and onl have enough material for 30 sets on hand. Who's in? Attached thumbnail(s) |
bbrock |
Jan 13 2018, 04:50 PM
I'm in for one set.
Lo-Fi Version | Time is now: 9th June 2024 - 04:07 AM |
