| holtby914 |
Jan 14 2018, 02:42 PM
Newbie ![]() Group: Members Posts: 42 Joined: 16-November 16 From: Ontario, Canada Member No.: 20,593 Region Association: Canada |
Trying to figure out what is the biggest wheels that will fit with gt flares... anyone have some advice? I found some decently priced generic steal wheels from diamond wheels that are 16X8(-12 offset). Can they be made to fit?
| GeorgeRud |
Jan 14 2018, 05:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
I know my 914-6 conversion car with GT flares has plenty of space up front running 15x7” Fuchs ( I don’t have access to their ET right now), so I think 8” should not be an issue as long as your tire size keeps a similar outer diameter. I have seen photos of 17” Ruf wheels fitted to aflated car, so 16” shouldn’t be an issue.
If possible, post pics of the wheels you’re planning to use. |
holtby914 wheel sizes... will 16x8 work with flares? Jan 14 2018, 02:42 PM
914 Ranch What is a -12 offset? I run 8 16 Panasports with 2... Jan 14 2018, 04:07 PM
holtby914 Here is a wheel offset diagram:
https://www.googl... Jan 14 2018, 04:12 PM
Mark Henry If you have the right offset you can run 8" a... Jan 14 2018, 06:04 PM
holtby914 Thanks for advice. The wheels I was looking at ar... Jan 14 2018, 06:17 PM
Mueller http://www.914world.com/bbs2/index.php?s=&...t... Jan 14 2018, 06:27 PM
holtby914
http://www.914world.com/bbs2/index.php?s=&...t... Jan 14 2018, 08:09 PM
Mueller
[quote name='Mueller' post='2568234' date='Jan 14... Jan 14 2018, 08:30 PM
holtby914
[quote name='Mueller' post='2568234' date='Jan 1... Jan 14 2018, 08:38 PM
holtby914
[quote name='Mueller' post='2568234' date='Jan 1... Jan 14 2018, 08:41 PM
gothspeed
http://www.914world.com/bbs2/index.php?s=&...t... Jan 14 2018, 08:33 PM
echocanyons You will need a spacer in the rear with 16 x 8 951... Jan 14 2018, 06:29 PM
Perry Kiehl I've seen 8 & 9 x 16"s on a 914 wideb... Jan 14 2018, 07:06 PM
gothspeed
I've seen 8 & 9 x 16"s on a 914 wide... Jan 14 2018, 08:05 PM
holtby914 That site is great. Thanks! Jan 14 2018, 07:42 PM
echocanyons Mine are a stock 944 spacer 23mm if I recall corre... Jan 14 2018, 08:16 PM
gothspeed
Mine are a stock 944 spacer 23mm if I recall corr... Jan 14 2018, 08:30 PM
Mueller
Mine are a stock 944 spacer 23mm if I recall corr... Jan 14 2018, 08:33 PM
holtby914
Mine are a stock 944 spacer 23mm if I recall cor... Jan 14 2018, 08:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:23 AM |
