> wheel sizes... will 16x8 work with flares?
holtby914
post Jan 14 2018, 02:42 PM
Trying to figure out what is the biggest wheels that will fit with gt flares... anyone have some advice? I found some decently priced generic steal wheels from diamond wheels that are 16X8(-12 offset). Can they be made to fit?
Mueller
post Jan 14 2018, 06:27 PM
914 Freak!
http://www.914world.com/bbs2/index.php?s=&...t&p=1270311
^ His offset should be (no mention of spacers used)
F = 23.3mm
R = 15mm]
I like http://www.willtheyfit.com/ for playing with offsets.
holtby914
post Jan 14 2018, 08:09 PM
QUOTE(Mueller @ Jan 14 2018, 07:27 PM) *
F = 23.3mm
R = 15mm]
Thanks for info... Would converting to 5-lug be worth it doing now before I order wheels? Is the only advantage that there is better wheel selection to choose from?
Mueller
post Jan 14 2018, 08:30 PM
914 Freak!
QUOTE(holtby914 @ Jan 14 2018, 06:09 PM) *
F = 23.3mm
R = 15mm]
Better brakes with 5 lug if you swap over to 911 front suspension.
/4 front are solid rotor
911 front is vented and there are kits to put larger and lighter calipers.
Besides being cheap why the Circle track heavy steel rims?
Define "worth it" (IMG:style_emoticons/default/smile.gif) It's only money.
holtby914   wheel sizes... will 16x8 work with flares?   Jan 14 2018, 02:42 PM
914 Ranch   What is a -12 offset? I run 8 16 Panasports with 2...   Jan 14 2018, 04:07 PM
holtby914   Here is a wheel offset diagram: https://www.googl...   Jan 14 2018, 04:12 PM
GeorgeRud   I know my 914-6 conversion car with GT flares has ...   Jan 14 2018, 05:08 PM
Mark Henry   If you have the right offset you can run 8" a...   Jan 14 2018, 06:04 PM
holtby914   Thanks for advice. The wheels I was looking at ar...   Jan 14 2018, 06:17 PM
Mueller   http://www.914world.com/bbs2/index.php?s=&...t...   Jan 14 2018, 06:27 PM
holtby914   http://www.914world.com/bbs2/index.php?s=&...t...   Jan 14 2018, 08:09 PM
Mueller   [quote name='Mueller' post='2568234' date='Jan 14...   Jan 14 2018, 08:30 PM
holtby914   [quote name='Mueller' post='2568234' date='Jan 1...   Jan 14 2018, 08:38 PM
holtby914   [quote name='Mueller' post='2568234' date='Jan 1...   Jan 14 2018, 08:41 PM
gothspeed   http://www.914world.com/bbs2/index.php?s=&...t...   Jan 14 2018, 08:33 PM
echocanyons   You will need a spacer in the rear with 16 x 8 951...   Jan 14 2018, 06:29 PM
Perry Kiehl   I've seen 8 & 9 x 16"s on a 914 wideb...   Jan 14 2018, 07:06 PM
gothspeed   I've seen 8 & 9 x 16"s on a 914 wide...   Jan 14 2018, 08:05 PM
holtby914   That site is great. Thanks!   Jan 14 2018, 07:42 PM
echocanyons   Mine are a stock 944 spacer 23mm if I recall corre...   Jan 14 2018, 08:16 PM
gothspeed   Mine are a stock 944 spacer 23mm if I recall corr...   Jan 14 2018, 08:30 PM
Mueller   Mine are a stock 944 spacer 23mm if I recall corr...   Jan 14 2018, 08:33 PM
holtby914   Mine are a stock 944 spacer 23mm if I recall cor...   Jan 14 2018, 08:43 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 03:09 PM
