Raleigh NC Looking for a repair shop Djet specialist, 2.0l 75 914 |
rfinegan |
Jan 19 2018, 09:13 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I need to find a shop that can work and repair a 2.0 Djet.. I recently installed the system back on my 75 914 2.0l It had weber a carb conversion . It runs well at High way speeds but at idle and off idle it has a stumble /miss. At idle it is sometimes good but often gets rough and surges
Cold start is fine for the first 30 sec to a min then it will start stumbling and missing off idle. IT runs better when warmer and seems to idle best once coming off a hi way cruise =Robert |
DRPHIL914 |
Jan 19 2018, 02:21 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I need to find a shop that can work and repair a 2.0 Djet.. I recently installed the system back on my 75 914 2.0l It had weber a carb conversion . It runs well at High way speeds but at idle and off idle it has a stumble /miss. At idle it is sometimes good but often gets rough and surges Cold start is fine for the first 30 sec to a min then it will start stumbling and missing off idle. IT runs better when warmer and seems to idle best once coming off a hi way cruise =Robert vacuum leak suspected, or lean running, could be bad MPS developing too. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:47 PM |
