I can fix headers, with a common problem |
ChrisFoley |
May 16 2003, 07:27 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Kerry Hunter Headers (and others) have a common problem. The little ears that go over the studs bend and make it harder to mount. They also crack the pipe sometimes when you tighten the nuts a little more to get rid of that pesky exhaust leak, making things worse.
Attached image(s) |
ChrisFoley |
May 16 2003, 07:30 AM
I can cut those things off and replace them with the machined blocks I use on my stub pipes. You can apply more torque, safely. They line up better with the studs so there is less chance of leaks when torqued carefully.
Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:20 PM |
