malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
This happened to me before. I wish I could remember what I (or we) did to fix it. I did a search for my posts and it did not jump out at me. So if anyone remembers, or has recently repaired this, speak up....
OK here is the deal. I activate the turn signal lever and sometimes the dash indicator will blink twice. Most times not. I don't hear a CLICK when they do work. The Hazards do the same thing. The fuse is fine. The parking feature works fine on either side. Does everyone know that when the key is off and out, if you activate the signal lever, the lights come on on that side? Let know... |
malcolm2 |
Spoke,
I have gotten with Pelican about the problem and returning the part. I have a bit of a hybrid tach set up. My car is a 75, I backdated the gauges to silver dot. Tim_ND helped me get the 2 blinkers working using the hazard wiring. I have a wiring layout somewhere if you want to see it. So my question is, would I need the 911 relay or the modified 914 relay you sell? Are they different? |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Spoke, I have gotten with Pelican about the problem and returning the part. I have a bit of a hybrid tach set up. My car is a 75, I backdated the gauges to silver dot. Tim_ND helped me get the 2 blinkers working using the hazard wiring. I have a wiring layout somewhere if you want to see it. So my question is, would I need the 911 relay or the modified 914 relay you sell? Are they different? It's the same part for 911 and 914 w/2 indicators. Only different variation is 914 with 1 indicator. In this case the C2 pin gets connected to 49a when the flasher is active. |
malcolm2 |
Spoke, I have gotten with Pelican about the problem and returning the part. I have a bit of a hybrid tach set up. My car is a 75, I backdated the gauges to silver dot. Tim_ND helped me get the 2 blinkers working using the hazard wiring. I have a wiring layout somewhere if you want to see it. So my question is, would I need the 911 relay or the modified 914 relay you sell? Are they different? It's the same part for 911 and 914 w/2 indicators. Only different variation is 914 with 1 indicator. In this case the C2 pin gets connected to 49a when the flasher is active. Ok. Since the original one worked as i have it wired now i'll buy your 914 one. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:16 AM |
