QUOTE(Spoke @ Jul 30 2019, 10:14 PM)
QUOTE(Minerva's 914 @ Jul 30 2019, 09:46 PM)
Spoke, I clicked thru to your website based on this thread and a problem I'm experiencing with my brake light flashing and weak right turn signal dash light (blinks normally on the dash for 2 blinks and then both right and left indicators flash very dimly, though the front and rear lights blink normally). I click thru to the 914 link and ordered a relay, sent payment info, etc. I haven't received the relay, nor heard anything about the order. I just went back to your website and now when I click on 914 the page is blank.
HELP
I have your order. I'll get it out tomorrow. Sorry for the delay. Not a fun week for us. My wife broke her ankle and I've been the home nurse for the last week.
The website is still up. Maybe some cache issues?
@spoke Thank you so much for your excellent service, the relay arrived quickly. I had to leave last week for a trip to Charleston so this weekend was the first opportunity to jump on the 914.
The turn signal switch had not been cancelling after returning to center for a long time so I ordered a replacement and thought I'd do the whole thing at the same time. I replaced the switch and checked to see if that by any chance corrected either the dim double flashing or by some outside chance also corrected the brake light warning flashing. Nope,.okay I didn't think so but worth a try.
Installed the new relay and the turn signals functioned normally. The left signal continued to work fine and the right turn signal stopped the dim double blinking it was doing before and gave a solid flashing. Unfortunately the parking brake light continued to flash all the time HOORAY I thought I was half way there.
As I continued to search for the cause of the braking brake light problem I discovered that the brake master cylinder switch was a single pole switch not the double pole that was needed and was not hooked up at all. I tried hooking up each of the two wires individually, then hooking up each and grounding the other one but nothing seemed to make any difference.
I ordered the correct switch today and will replace it next week when it arrives. I reinstalled the steering wheel and started the car to test the horn and turn signals, flipped the turn signal to the right turn position and the left turn indicator was flashing, tried the left turn position and the right turn indicator was flashing. I pulled the new relay out and reinstalled the old one and now both turn signals and indicators operate normally with the old relay. Returned the new relay to the car and the reversed indicator continues. Btw, the front and rear turn signals continue to function normally the whole time.
I pulled the instrument panel and I see there is a resistor inline to the brake light warning light. Resistor #41806. Wondering if that could possibly be the problem. Can't find on online, any idea what the resistor value is for the resistor or where I can find one.
Thinking about switching to Lucus electric system.
You really seem to know your stuff and I'm hoping that you can give some insight to what is happening here.
Thanks in advance for your help.
