Replacing Fuel Lines |
Coloradocurt |
Feb 2 2018, 01:31 PM
Member Group: Members Posts: 65 Joined: 20-November 16 From: Castle Rock, Colorado Member No.: 20,603 Region Association: Rocky Mountains |
In doing my research prior to replacing the original fuel lines with stainless ones, I've gotten the impression that the originals were installed with a couple sets of metal hold-down tabs inside the center tunnel. With my shifter removed, I've found one set immediately adjacent to the shifter towards the passenger-side door. But is there a 2nd set, and if so, where is it located?
Thanks |
bbrock |
Feb 2 2018, 04:32 PM
I just took a peek at mine to be sure. The front clip is accessed through the hole for the shifter plate. The rear one is under the rear hole where the wire harness enters the tunnel before going through the fire wall. That probably isn't great news if you harness is in the car, but might help you locate it at least.
Lo-Fi Version | Time is now: 2nd June 2024 - 11:12 AM |
