Replacing Fuel Lines |
Coloradocurt |
Feb 2 2018, 01:31 PM
Member Group: Members Posts: 65 Joined: 20-November 16 From: Castle Rock, Colorado Member No.: 20,603 Region Association: Rocky Mountains |
In doing my research prior to replacing the original fuel lines with stainless ones, I've gotten the impression that the originals were installed with a couple sets of metal hold-down tabs inside the center tunnel. With my shifter removed, I've found one set immediately adjacent to the shifter towards the passenger-side door. But is there a 2nd set, and if so, where is it located?
Thanks |
TheCabinetmaker |
Feb 2 2018, 09:33 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Don't use the braided line unless it's rated for ethanol. I won't use it period! They leak.
Wyvern |
Feb 3 2018, 01:19 AM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Don't use the braided line unless it's rated for ethanol. I won't use it period! They leak. Thank you ... now you got me worried ... Cohline 2122 is rated German OEM, rated for up to 50% ethanol mixture, E10 up to a maximum of E50. Working Temperature -22F to 150F Working Pressure at ambient temperature (68F) is 101 psi / 7 bar. Should I be using something else ? |
Lo-Fi Version | Time is now: 2nd June 2024 - 11:01 AM |
