| lonewolfe |
Feb 3 2018, 07:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Are any of you running a retun fuel line with carbs?
| lonewolfe |
Feb 5 2018, 12:41 AM
I have Dellorto carbs so one has the menu intake line & a double banjo that then feeds the second carb. I was thing if both carbs had double banjo’s that the second outlet on the the slave carb could run as a return line. Do you guys think that would work ok? I do not believe my fuel pressure regulator has an option for a return line.
lonewolfe Return fuel line with carbs? Feb 3 2018, 07:06 PM
struckn I'm not running a return line...actually I had... Feb 3 2018, 08:38 PM
brant Yes.
A return fuel line in s a good thing.
Kee... Feb 3 2018, 08:51 PM
Larmo63 On a six with Webers, I'm not sure how it work... Feb 3 2018, 09:05 PM
jcambo7
On a six with Webers, I'm nt sure how it work... Feb 3 2018, 09:45 PM
porschetub
On a six with Webers, I'm nt sure how it work... Feb 3 2018, 11:11 PM
mmascari
On a six with Webers, I'm nt sure how it wor... Feb 3 2018, 11:17 PM
brant
On a six with Webers, I'm not sure how it wor... Feb 4 2018, 08:19 AM
Krieger To be clear the rectangle is the filter. Circle i... Feb 4 2018, 10:59 PM
brant
To be clear the rectangle is the filter. Circle ... Feb 5 2018, 12:37 PM
gothspeed I like option E with double barb banjos on the car... Feb 5 2018, 12:21 AM
bbrock
I like option E with double barb banjos on the ca... Feb 5 2018, 08:27 AM
gothspeed
I like option E with double barb banjos on the c... Feb 5 2018, 08:42 AM
Racer Chris
I like option E with double barb banjos on the c... Feb 5 2018, 08:46 AM
bbrock
[quote name='bbrock' post='2575289' date='Feb 5 2... Feb 5 2018, 10:22 AM
anderssj I've been running dual dell's with an ... Feb 5 2018, 09:48 AM
Socalandy covered here, im running tangerine lines with PMO ... Feb 5 2018, 09:54 PM
North Coast Jim No return line in use with 44 IDFs. Car runs great... Feb 6 2018, 08:09 AM
1adam12 What's up guys! I just purchased a pair o... Feb 21 2018, 11:03 AM
bbrock
What's up guys! I just purchased a pair ... Feb 21 2018, 01:48 PM
rhodyguy Get the self regulated carter pump. Keep it simple... Feb 21 2018, 12:53 PM
1adam12
Get the self regulated carter pump. Keep it simpl... Feb 21 2018, 03:55 PM
rgolia Not sure I get the return line need/benefit with c... Feb 21 2018, 02:56 PM
bbrock This is just from what I've read on the Intern... Feb 21 2018, 03:28 PM
1adam12 Thanks
rhodyguy
bbrock
rgolia
For the input. I g... Feb 21 2018, 03:41 PM
brant also...
I've run many a rotary or low pressur... Feb 21 2018, 04:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th May 2026 - 08:11 AM |
