> Return fuel line with carbs?, Anyone running return fuel line with cabs?
lonewolfe
post Feb 3 2018, 07:06 PM
Are any of you running a retun fuel line with carbs?
gothspeed
post Feb 5 2018, 12:21 AM
I like option E with double barb banjos on the carbs (IMG:style_emoticons/default/smile.gif)
But it would depend on the type and range of regulator. Second choice would be option D with a Y feeding carbs.
bbrock
post Feb 5 2018, 08:27 AM
QUOTE(gothspeed @ Feb 4 2018, 11:21 PM) *
But it would depend on the type and range of regulator. Send choice would be optio D with a Y feeding carbs.
To make sure I understand correctly, C and D would require a bypass style regulator while B and E would use blocking type. Do I have that right?
ChrisFoley
post Feb 5 2018, 08:46 AM
I am Tangerine Racing
QUOTE(bbrock @ Feb 5 2018, 10:27 AM) *
Yes, except that in option B the upstream regulator is useless. A blocking regulator is needed downstream.
We had a 914 here recently which came with a single carb that had an internal regulator. It needed the return line to work.
Otherwise I don't think I've ever seen a 914 with a carb setup in my shop (other than stock 914-6) that used a return line.
lonewolfe   Return fuel line with carbs?   Feb 3 2018, 07:06 PM
struckn   I'm not running a return line...actually I had...   Feb 3 2018, 08:38 PM
brant   Yes. A return fuel line in s a good thing. Kee...   Feb 3 2018, 08:51 PM
Larmo63   On a six with Webers, I'm not sure how it work...   Feb 3 2018, 09:05 PM
jcambo7   On a six with Webers, I'm nt sure how it work...   Feb 3 2018, 09:45 PM
porschetub   On a six with Webers, I'm nt sure how it work...   Feb 3 2018, 11:11 PM
mmascari   On a six with Webers, I'm nt sure how it wor...   Feb 3 2018, 11:17 PM
brant   On a six with Webers, I'm not sure how it wor...   Feb 4 2018, 08:19 AM
Krieger   To be clear the rectangle is the filter. Circle i...   Feb 4 2018, 10:59 PM
brant   To be clear the rectangle is the filter. Circle ...   Feb 5 2018, 12:37 PM
gothspeed   I like option E with double barb banjos on the car...   Feb 5 2018, 12:21 AM
bbrock   I like option E with double barb banjos on the ca...   Feb 5 2018, 08:27 AM
gothspeed   I like option E with double barb banjos on the c...   Feb 5 2018, 08:42 AM
Racer Chris   I like option E with double barb banjos on the c...   Feb 5 2018, 08:46 AM
bbrock   [quote name='bbrock' post='2575289' date='Feb 5 2...   Feb 5 2018, 10:22 AM
lonewolfe   I have Dellorto carbs so one has the menu intake l...   Feb 5 2018, 12:41 AM
anderssj   I've been running dual dell's with an ...   Feb 5 2018, 09:48 AM
Socalandy   covered here, im running tangerine lines with PMO ...   Feb 5 2018, 09:54 PM
North Coast Jim   No return line in use with 44 IDFs. Car runs great...   Feb 6 2018, 08:09 AM
1adam12   What's up guys! I just purchased a pair o...   Feb 21 2018, 11:03 AM
bbrock   What's up guys! I just purchased a pair ...   Feb 21 2018, 01:48 PM
rhodyguy   Get the self regulated carter pump. Keep it simple...   Feb 21 2018, 12:53 PM
1adam12   Get the self regulated carter pump. Keep it simpl...   Feb 21 2018, 03:55 PM
rgolia   Not sure I get the return line need/benefit with c...   Feb 21 2018, 02:56 PM
bbrock   This is just from what I've read on the Intern...   Feb 21 2018, 03:28 PM
1adam12   Thanks rhodyguy bbrock rgolia For the input. I g...   Feb 21 2018, 03:41 PM
brant   also... I've run many a rotary or low pressur...   Feb 21 2018, 04:15 PM
- Lo-Fi Version Time is now: 25th May 2026 - 08:11 AM
