Tips on removing a wiring harness? |
Tdskip |
Feb 5 2018, 07:28 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
I want to remove the wiring harness from the 1971 donor car that I have, and was hoping to get some advice on do’s and don’ta when going after that.
Thanks! |
PlantMan |
Feb 6 2018, 12:33 AM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
I did this recently.
I spent more time thinking about how I was going to do it than I actually spent pulling out the harness. (IMG:style_emoticons/default/biggrin.gif) I got myself a roll of white electrical tape of good quality. I picked-up a couple permanent black pens that are suitable for plastic. Sharpie will not work. Good Pens for Plastic I started the process in the rear of the car and took one job at a time (ie. right rear light, license plate light, left rear light, trunk light)making sure I labeled all wires as i disconnected them. Then when I thought I had every thing disconnected I mythodically unstrapped the wire from all connectors/straps and slowely worked around the trunk. I eventually pulled the wires through and into the engine bay. I then went on to the next task and took my time, each time with the same process. Eventually I had everything disconnected from the rear portion of the car and then slowly pulled the bundle through the firewall. The firewall was a PITA. In all, I probably spent 5-6 hours labeling everything, removing and pulling wires, documenting with pics, etc. Probably not the most rewarding job until you put the thing back in. Enjoy! |
bbrock |
Feb 6 2018, 08:50 AM
I did this recently. I spent more time thinking about how I was going to do it than I actually spent pulling out the harness. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) I pulled mine a few months ago and it wasn't as bad as I thought it would be. I bought a package of these zip tie labels and like them much better than tape. Also, after downloading a copy of your wiring diagram from Jeff Bowlsby's site, you'll find you don't need to label a lot of the wires. I didn't trust that everything was wired correctly as I pulled it off the car anyway. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:59 PM |
