I did this recently.
I spent more time thinking about how I was going to do it than I actually spent pulling out the harness.
I got myself a roll of white electrical tape of good quality. I picked-up a couple permanent black pens that are suitable for plastic. Sharpie will not work.
Good Pens for PlasticI started the process in the rear of the car and took one job at a time (ie. right rear light, license plate light, left rear light, trunk light)making sure I labeled all wires as i disconnected them. Then when I thought I had every thing disconnected I mythodically unstrapped the wire from all connectors/straps and slowely worked around the trunk. I eventually pulled the wires through and into the engine bay.
I then went on to the next task and took my time, each time with the same process. Eventually I had everything disconnected from the rear portion of the car and then slowly pulled the bundle through the firewall. The firewall was a PITA.
In all, I probably spent 5-6 hours labeling everything, removing and pulling wires, documenting with pics, etc.
Probably not the most rewarding job until you put the thing back in.
Enjoy!
